JMZ
January 16, 2017, 6:18pm
3
[quote=“[deleted], post:2, topic:72299”]
There is also a ST smartapp called ‘Blue Iris Fusion’ which allows you to trigger ST events based on Blue Iris motion triggers and also change recording modes in Blue Iris based on ST events.
[/quote]
Just to clarify, Blue Iris Fusion uses Smartthings triggers to activate recording on Blue Iris Cameras:
Note, BI Fusion v3.0 is out and offers major upgrades, warranting a new thread. A lot of the info in this thread is still good, but I recommend visiting the new one:
Hello all,
Do it all in one app! Blue Iris Fusion combines profile integration with camera triggering so you SmartThings Modes and sensors can update Blue Iris’ profile and trigger it’s cameras to record. You can connect SmartThings to Blue Iris via local IP connection (LAN) or over the normal external cloud connection (WAN).
Simply install the parent app (which has the login info so you don’t have to do it multiple times), setup the Blue Iris Profiles, and then add triggers (it calls the child app) for each camera. As noted, be careful when entering your camera name (it’s the short name in Blue Iris, and is case sensi…
You can also create virtual motion devices to have Blue Iris motion detection trigger Smartthings notifications (read the top of the thread for setup directions):
Well, I couldn’t get Kubicki’s Smart App to work either, but I didn’t try too hard because the IFTTT setup is super easy. Got it going, thanks @rcrosier !
Edit: I actually have this triggering a simulated motion sensor, not a switch, so I can use it for Smart Home Monitor and other alert-type things. The camera/Blue Iris combo handles outdoor motion much better than anything else I’ve tried. I couldn’t find any Simulated Switch + Motion device type handlers, so I just whipped this one up:
https://github.com/flyjmz/jmzSmartThings/tree/master/devicetypes/flyjmz/virtual-motion-switch.src
Hope it helps.
Once you have those virtual devices set up, you can use this notification app for a lot of control:
Combines ‘Left it Open’ with ‘Notify Me When’ in a convenient parent-child smart app (decluttering your smartapp list), plus includes:
Custom frequency of notifications
Notification Restriction Options for certain Modes, Times of day, Days of week, Sunrise/sunset
Periodic Notifications - Recurring notifications after the initial one, based on either a separate custom time period, or at sunrise/sunset, or when mode changes
Adds something left on (or off), something left closed (or open), lock left unlocked (or locked), and temperature still too hot (or cold)
Can handle when something is left open/closed/on/off/locked/unlocked/too hot/too cold while in a mode or time period that wouldn’t generate a notification, but remember it and notify you when the mode/time changes to a one that does (…
