It covers how to flash device using the example from GitHub however, I have no clue on how to change the code to work for my needs. Basically looking for some tutorial or documentation that can help me learn that.
I am willing to pay for someone to teach me.
As an example, I would like to be able to control 4 relays using a single ESP32 and have 4 cards for their respective control on SmartThings app. Maybe also a fan control to understand how to implement other capabilities.
Anything is welcome. Code suggestions, videos, docs or tutoring etc.
Have you tried the ESP32 Espressif forum - https://www.esp32.com/viewforum.php?f=13 ?
The STDK ESP32 chipset support is based on ESP-IDF which in itself is based on FreeRTOS, maybe you should start there. I had to stumble around the examples on the ESP-IDF repo and STDK-ref repo to understand how stuff fit together.
I have been struggling to add additional capabilities to the code but have no clue on how to go around doing that. Like adding a fan control etc… or even touch input from ESP32 pins.
Have offered to pay and requested help in the following posts but no one is responding -
If you figure something out, I would love to hear it!!
EDIT - this is the sample code I requested from one of the devs, not sure if I will get a reply - “Can we have an ESP32 controlling say - two switches, a fan and maybe even displaying readings from temp/humidity sensor in a single device. A recorded demo of how would you go around coding this from scratch. Maybe even include how to integrate touch inputs etc… whatever common scenarios you can think of…”
