I’ll start out with this, I’m not a good programmer, by any means, I will probably never fully get this down.
I’ve been using the Built-in Smart Lighting app like crazy to set colors and scenes for my Lightify bulbs, which are now all over the house. 2 things I don’t like about the app:
- It’s built for Hue, which means the colors are off with Lightify. Blue is purple, green is turquoise, purple is pink, etc.
- It only lets you set dim levels in 10% increments. I prefer 5% or less, especially for movie nights.
I wanted to simply modify the source code, which would be EASY, but I found out that the source code is a guarded secret. Plan B, I found this sample app, which is a simplified version:
http://docs.smartthings.com/en/latest/smartapp-developers-guide/parent-child-smartapps.html#example
Bingo, a good app for me to start with. I needed to make 4 modifications, though:
- Change the 10-20-30…% increment enum to a simple integer value, so I could input any value I want.
- Add some more color choices, like Teal, Sky Blue, Indigo, etc.
- I don’t want to activate at a certain time, but rather when the mode changes. (this also means I deleted the line for “Off time”)
- I will still need to go in and tweak the color values for Lightify.
For now, the program compiles, but I get an unknown error in the app.
definition(
name: "Simple Automation",
namespace: "mynamespace/automations",
author: "Your Name",
description: "A simple app to control basic lighting automations. This is a child app.",
category: "My Apps",
// the parent option allows you to specify the parent app in the form <namespace>/<app name>
parent: "mynamespace/parent:Simple Lighting",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
page name: "mainPage", title: "Automate Lights & Switches", install: false, uninstall: true, nextPage: "namePage"
page name: "namePage", title: "Automate Lights & Switches", install: true, uninstall: true
def installed() {
log.debug "Installed with settings: ${settings}"
subscribe(location, "mode", modeChangeHandler)
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unschedule()
initialize()
def initialize() {
// if the user did not override the label, set the label to the default
if (!overrideLabel) {
app.updateLabel(defaultLabel())
def allModes = location.modes // ex: [Home, Away, Night]
log.debug "all modes for this location: $allModes"
// main page to select lights, the action, and trigger mode
def mainPage() {
dynamicPage(name: "mainPage") {
section {
lightInputs()
actionInputs()
modeInputs()
// page for allowing the user to give the automation a custom name
def namePage() {
// if the user selects to not change the label, give a default label
def l = defaultLabel()
log.debug "will set default label of $l"
app.updateLabel(l)
dynamicPage(name: "namePage") {
if (overrideLabel) {
section("Automation name") {
label title: "Enter custom name", defaultValue: app.label, required: false
} else {
paragraph app.label
section {
input "overrideLabel", "bool", title: "Edit automation name", defaultValue: "false", required: "false", submitOnChange: true
// inputs to select the lights
def lightInputs() {
input "lights", "capability.switch", title: "Which lights do you want to control?", multiple: true, submitOnChange: true
// inputs to control what to do with the lights (turn on,, turn off, turn on and set color, turn on and set level)
def actionInputs() {
if (lights) {
input "action", "enum", title: "What do you want to do?", options: actionOptions(), required: true, submitOnChange: true
if (action == "level" || action == "color") {
input "level", "number", title: "Dimmer Level", defaultValue: "50"
if (action == "color") {
input "color", "enum", title: "Color", required: true, multiple:false, options: [
["Soft White":"Soft White"], ["Cool White":"Cool White"], ["Daylight":"Daylight"], ["Warm White":"Warm White"],
"Red","Green","Blue","Aqua","Sky","Indigo","Lime","Mint","Yellow","Orange","Purple","Pink"]
// utility method to get a map of available actions for the selected switches
def actionMap() {
def map = [on: "Turn On", off: "Turn Off"]
if (lights.find{it.hasCommand('setLevel')} != null) {
map.level = "Turn On & Set Level"
if (lights.find{it.hasCommand('setColor')} != null) {
map.color = "Turn On & Set Color/Level"
map
// utility method to collect the action map entries into maps for the input
def actionOptions() {
actionMap().collect{[(it.key): it.value]}
// inputs for selecting modes
def modeInputs() {
if (settings.action) {
section {
input "modes", "mode", title: "select a mode(s)", multiple: true, required: true
// a method that will set the default label of the automation.
// It uses the lights selected and action to create the automation label
def defaultLabel() {
def lightsLabel = settings.lights.size() == 1 ? lights[0].displayName : lights[0].displayName + ", etc..."
"Turn on and set color of $lightsLabel"
} else if (action == "level") {
"Turn on and set level of $lightsLabel"
} else {
"Turn $action $lightsLabel"
// the handler method that turns the lights on/off and sets level and color if specified
def actionHandler() {
// perform the selected action
switch(action) {
case "level":
lights.each {
// check to ensure the switch does have the setLevel command
if (it.hasCommand('setLevel')) {
it.setLevel(level as Integer)
it.on()
break
case "on":
lights.on()
break
case "color":
setColor()
break
case "off":
lights.off()
break
// set the color and level as specified, if the user selected to set color.
def setColor() {
def hueColor = 0
def saturation = 100
switch(color) {
case "Cool White":
hueColor = 52
saturation = 19
break;
case "Daylight":
hueColor = 53
saturation = 91
break;
case "Soft White":
hueColor = 23
saturation = 56
break;
case "Warm White":
hueColor = 20
saturation = 80
break;
case "Red":
hueColor = 100
break;
case "Green":
hueColor = 39
break;
case "Blue":
hueColor = 70
break;
case "Aqua":
hueColor = 39
break;
case "Sky":
hueColor = 39
break;
case "Indigo":
hueColor = 39
break;
case "Lime":
hueColor = 39
break;
case "Mint":
hueColor = 39
break;
case "Yellow":
hueColor = 25
break;
case "Orange":
hueColor = 10
break;
case "Purple":
hueColor = 75
break;
case "Pink":
hueColor = 83
break;
def value = [switch: "on", hue: hueColor, saturation: saturation, level: level as Integer ?: 100]
log.debug "color = $value"
lights.each {
if (it.hasCommand('setColor')) {
it.setColor(value)
} else if (it.hasCommand('setLevel')) {
it.setLevel(level as Integer ?: 100)
} else {
it.on()
