So I’m working on an app to check the current state of multiple open/close devices. Obviously I can have the user input multiple sensors by adding the “multiple: true” to the preferences section. And if not mistaken the devices are known as sensor1, sensor2, sensor3, etc. (assuming I put sensor as the input name). But how do I know how many devices the user selected when installed?
What I’d like to do is check each sensor and then send a text if with the name of a sensor that is open.
In the link above, you can see how I’d done that exact thing, then string them togther with ", " as the join glue - and check teh count to see how the verbiage should be changed.
It actually is an array of sensors and you an call the “size” method. Try “def myCount = sensor.size”. You can get to each one like sensor[0] for the first one and sensor[1] for second, and so on. So if you wnated to cycle through them all:
for (def cntr = 0; cntr < sensor.size; cntr++) {
//do something in code
sensor[cntr].on()
