Hi there,
I’m currently writing a SmartApp to “connect” my ST Multipurpose sensors to a local machine via httpPost and sync the open/close events.
Code worked pretty well for a single Sensor hence I started with multiple Sensors which are stored in an array.
Now, when subscribing to the sensor events in the array (“contact.open” and “contact.close”) I noticed that somehow the function triggered threw an open or close event cannot distinguish, which sensor was triggering it (in below example the it.getID() always returns an array of all sensors IDs in the initial array but not the sensor which triggered the event)
Would anyone have an idea how to distinguish the triggering device in open or close event (have only the ID of the sensor which was opened/closed)?
preferences {
section(“Select Sensors:”) {
input “myDevice”, “capability.contactSensor”, required: true, title: “Which Sensor”, multiple:true
def initialize() {
subscribe(myDevice, “contact.open”, myOpen)
(I also tried to subscribe individually per sensor but with same result)
def initialize() {
myDevice.each {
subscribe(it, “contact.open”, myOpen)
def myOpen(evt) {
try {
httpPost(“http://SOMEURL/client.php","command=${it.getId()}:I0=0”) { resp ->
log.debug “response data: ${resp.data}”
log.debug “response contentType: ${resp.contentType}”
} catch (e) {
log.debug “something went wrong: $e”
