Before I updated to hub v2, I was using three apps from @sidjohn1 for my two Nests; Thermostat Auto Away, Auto Home, and Timed Mode Change. Unfortunately, the Timed Mode Change is no longer available and I didn’t save the code to it.
What I need is the following:
Set Nests Away when I leave (with adjustable time delay) and Home when I arrive. The Auto Away and Auto Home apps take care of this.
Set the Nest back to Home at a specific time everyday. Would be even better if I can choose to do this only Monday through Friday. My wife gets home from work at about the same time every day and I want to start the heating and cooling process before she arrives so that the house is comfortable. Would also need to be able to disable in certain modes, ie Vacation…
I don’t use the Nest’s auto-away function. With the locations of them, I never had good results. Only thing I use on the Nest’s directly is the temperature schedule. But with that, there’s no way to set auto-home at a specific time.
Looking for something similar with my Nest Thermostat. Would like to be able to set Nest “Away” when ST mode goes to “Away” and when I return home and ST “home” mode is set, Nest thermostat will return to “Home” mode.
I’ve already programmed my Nest to know what I want when I am Home and when I am Away and I would prefer to use Nest learning mode for the finer settings. Just looking for a Smartapp to set the Nest mode on a mode trigger.
