I am looking for some technical expertise in connecting my Somfy controller bridge (model #1811265) to my SmartThings hub. I have the Somfy bridge connected to 4 screen motors and 4 shutter motors. That seems to be working.
I haven’t been able to connect the Somfy controller to the SmartThings hub. It seemed to connect one shutter on it’s own but it doesn’t allow me to add others. I’m perplexed.
@DaveB I (and others in here) are in the process of dumping the ZRTSI Somfy bridge and accompanying ST custom DH and migrating to a Bond Bridge and using the Bond Bridge Edge driver written by @blueyetisoftware. (he recently added the MY preset position to it)
Thanks @uberrob . That MY button is in the alpha channel, but will be in the beta channel soon. @DaveB The Bond Bridge as an RF / IR emitter. You add the codes/remotes for your blinds to that bridge, and then use the driver referenced above to control the Bond Bridge through SmartThings. The driver is also local, so you can use it to enable automations that still work when the internet is out.
So how does the somfy device appear in SmartThings and sharptool rules? Do they have simply 3 states: Open / Close / Preset? I presume there’s no SetLevel (0-100) like a dimmer…
I would be interested in seeing a picture of a somfy device in SmartThings, as well as a SharpTools Rule controlling one, just to make sure i understand correctly.
The appearance is driven by the capabilities of the blinds and how they are setup in the Bond app. Not many blinds offer that dimmer level control within the bond app. If they do, the dimmer control would show up as well in ST. Here is an example without the dimmer.
Thanks… I have my Bond Bridge paired to my ST app via the Edge drivers, and I see the bridge in ST.
I added my Somfy shades and blinds into the Bond app, and they work fine.
How do I update the ST app to see the new Somfy devices added into the BOND app? (I tried powering OFF the Bond bridge, initiating a ST SCAN, powering ON the Bond bridge, thinking that might start a pairing process again, but no luck…)
You don’t need to initiate pairing again if the Bridge is paired. You can verify the pairing works by trying to adjust the brightness of the blue ring on the bridge from the ST device. If that works, it’s paired. To find new devices, you just need to go to discovery again.
If it isn’t paired, you should restart your Bond bridge, before going into ST discovery
Looks like it isn’t paired. I would delete the device and try again to discover. If that doesn’t pair, you can also manually pair it by going into the settings and providing the token. The token is in the Bond app. Go to the settings for your hub, go to advanced and look for local token. Give that to your hub device in ST.
Honestly @BartschLabs - I wouldn’t hold your breath. The ZRSTI was already out of date when it was brand new, tbh. I doubt anyone will support it anymore. Somfy is throwing their weight behind the Tohoma Bridge, and the Bond works great with Somfy.
@blueyetisoftware 's edge driver for Bond and the resulting Somfy app control is superior to what Somfy is offering with Tohoma, and the Bond is 1/2 the cost of the Tohoma.
Just cut your losses on the ZRTSI and shell out the $99 for the Bond. You’ll be waiting for a ZRTSI driver forever. I’m gonna eBay my ZRTSI, and I already have the Tohoma up on eBay. If no one buys either, off to the e-recycling center they go.
source: me. I’ve had all three devices. Bond w/ @blueyetisoftware 's edge driver wins hands down.
@uberrob, thank you for your insight and your endorsement says alot. The Bond bridge and @blueyetisoftware’s Edge driver sounds like the way to go if I want the blinds to be operable if I sell my home.
I also have a cheap Sonoff 433Mhz remote bridge that I was wondering if it would do RTS after Tasmotizing it and using the Tasmota Edge driver. Looks like maybe not. Then I noticed that people have built their own Somfy RTS MQTT bridges with cheap radios and ESP8266 microcontrollers. No guarantee that thhere would be Edge operability though. Now I must decide if easy or cheap are more important to me.
Hi @BartschLabs - no worries, I’m the chump that’s “tried them all” lol…so I am speaking from a place of practical experience.
The homebuilt RTS bridges are an option of course, but also sounds like a PitA - when cobbling something together, you gotta ask yourself “is my time worth more than $99?”
I’d just buy the Bond Bridge and call it a day. Works great.
