I think there is some confusion between what I posted and/or what you understood. I have no problems with Z-wave or Zigbee. Both networks are solid as stated above. My problems have to do with SmartThings itself, specifically “translation” from one protocol to the next.
For example, I have a Z-wave switch and a Hue Dimmer switch by my front door. The Z-wave switch controls a light by my door (not hue). If I press the Z-wave switch off, SmartThings/WebCore triggers and action to tell the Philips Hue bridge to turn off all the Hue Bulbs in my front yard (5 other bulbs). About 90% of the time, at least one bulb stays on. I have modified the WebCore piston to issue the Turn Off command, wait a minute and then re-issue the Turn Off command. This has gotten the fail rate down to maybe once per month. If I turn the Hue lights off pressing the Hue Dimmer switch to off, I get 100% success. So it appears as though the failure is in the commands being issued between SmartThings and Hue.
My zigbee mesh is solid. All zigbee sensors work as installed, no dropouts on the hub and the Hue network also works solid. My issue is specifically SmartThings issuing commands to Hue.
Interference is my wifi network and neighboring wifi networks causing my wifi to drop in and out. I have very strong signals in my house but I also have high noise levels across multiple wifi channels. Not related to Z-wave and I dont think I stated or implied that it was.
I do not know why I have WebCore issues with the sunrise or sunset statements. I use them for the front yard lights which are hue, but also with my garden lights (z-wave outlet) and my backyard patio lights (z-wave switches). There are days I come home and the lights are off and their are mornings I go out and the lights are on. It is not often, not as often as the SmartThings-Hue fumbles, but is noticeable. I would venture a guess of once to twice a month. I “suspect” this is a home wifi issue, where WebCore is getting processed but not communicated.
The WebCore delays are mostly not noticeable, except for where I use a Zigbee motion sensor to turn on a light. Delay is generally half a second to a full second, but occasionally longer. Just not sure why the delay. My hallways are short and you can easily be 5-ft in before the lights turn on sometimes…which at that point you start to step back to turn the light on…defeating the purpose. I have the same delay if I use the local Smart App and I suspect the cause is the custom GE device handler. Because I am using this device handler, the process is cloud based twice, once for WebCore and second for the device handler. Again, a local control would fix this. I need the custom DH for the double tap features that I use to establish scenes.
Yes, I do have some color hue bulbs that I wish to keep. None of them are controlled directly by a smart switch. They are mostly in lamps or accent lights, plugged in. Only in a few instances are they hardwired fixtures, and then the z-wave switch is in parallel, not direct control.
Motions are Lowe’s Iris Zigbee Sensors.
Thanks for sharing your thoughts, there some things to consider in there.
I don’t have time to go through everything right now, but I did want you to know I will look at it later.
