625alex
(Alex, ActionTiles Control Panel)
May 25, 2014, 5:30am
1
Good day SmartThingers!
I’m writing my first app, which is a Service Manager for Pushbullet. My end goal is to push notifications to certain devices.
I have trouble reading input on dynamic page of settings. I read into “devices” property, but it does not seem to be set. Whenever I try to output contents of “settings”, “devices” is not present, only “apiKey”.
Any help will be appreciated.
Thanks in advance!
Here is the code:
definition(
name: "PushBullet Manager",
namespace: "625alex",
author: "Alex Malikov",
description: "PushBullet Service Manager",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png"
preferences {
page(name: "Credentials", title: "Enter Credentials", nextPage: "listDevices", install: false) {
section("Enter API key...") {
input("apiKey", "text", title: "API Key", description: "Your Pushbullet API Key", required: true)
page(name: "listDevices", title: "Pushbullet Devices", content: "listDevices", install: false)
def listDevices()
def devices = listDevicesData()
def data = [:]
devices.each {
data[it.id] = it.name
log.debug "Device List = ${data}"
state.deviceData = devices
return dynamicPage(name: "listDevices", title: "Choose devices", install: true) {
section("Devices") {
input "devices", "enum", title: "Select Device(s)", required: false, multiple: true, options: data
def listDevicesData() {
def url = "https://${apiKey}@api.pushbullet.com/v2/devices"
httpGet(uri: url) { response ->
def devs = []
if (response?.data?.devices) {
response.data.devices.each { device ->
devs << [name: device.nickname, id: device.iden]
log.debug "Devices found: ${devs}"
return devs
def installed() {
log.debug "Installed with settings: ${settings}"
log.debug "installed $settings.devices"
//listDevices()
def updated() {
initialize()
//listDevices()
log.debug "Updated with settings: ${settings}"
log.debug "updated: $settings.devices"
def initialize() {
// TODO: subscribe to attributes, devices, locations, etc.
log.debug "initialize with settings: ${settings.devices}"
log.debug "state.deviceData: ${state.deviceData}"
leblaaanc
(Chris LeBlanc)
May 26, 2014, 2:51am
2
I’ve not used the multipage feature (yet) for any apps I’ve built so sorry I can’t be more helpful. I find this Pushbullet app interesting though, thanks for mentioning it.
625alex
May 26, 2014, 4:00pm
3
Bump.
I’m anxiously trying to get it working. There must be some minor mistake there. Please help!
urman
(Andrew Urman)
May 27, 2014, 5:59am
4
It looks like you never actually install the app. Both pages have install: false
Last one should be install: true
625alex
June 4, 2014, 11:35pm
5
I’m trying to write some code and the results are discouraging…
I don’t know if it’s me or the IDE.
Is the simulator working at this moment? I copied a basic On/Off Button Tile from device type samples and I have no output from logs.
625alex
June 5, 2014, 10:03pm
6
Hi!
I’m having some trouble with my device type.
When I run the following method:
def push(def message) { // ln 50
log.debug "state: $state" // ln 51
def toIden = state["iden"] // same for state.iden // ln 52
log.debug "iden: " + toIden // ln 53
parent.push(message, toIden) // ln 54
The log outputs the following:
3:54:15 PM: error java.lang.NullPointerException: Cannot get property ‘iden’ on null object @ line 53
3:54:15 PM: debug iden: 123
3:54:15 PM: debug state: [iden:123]
This is strange since getting this attribute works previously, state is not null and there’s nothing happening on line 53.
625alex
June 13, 2014, 7:02pm
7
Hi there,
Is there a way to make HTTP DELETE call?
Dianoga
(Brian Steere)
June 13, 2014, 7:05pm
8
625alex
June 14, 2014, 4:49am
10
Do we have an option to connect to a Web Socket in the IDE?
Dianoga
(Brian Steere)
June 15, 2014, 8:15pm
11
Not right now. I’ve mentioned it to them, but there isn’t a way to do it yet.
625alex
June 16, 2014, 2:56pm
12
Not even from SM to a third party service?
Polling frequently might get too expensive for both clouds…
Dianoga
(Brian Steere)
June 16, 2014, 3:07pm
13
Not that I’m aware of.
/cc @urman @dlieberman @bflorian
625alex
June 16, 2014, 9:18pm
14
What’s the proper way of using runIn command?
I’ve tried the following and I have nothing in the logs:
runIn(90, schedulePoll, [overwrite: false])
runIn(90, schedulePoll(), [overwrite: false])
runIn(90, "schedulePoll", [overwrite: false])
Also, there seems to be a zombie app running. Every now and then I see a log message from an instance that’s been uninstalled. That log message comes from same schedulePoll method, so it must have worked at some point. Not sure how to detect and permanently disable that instance…
Dianoga
(Brian Steere)
June 16, 2014, 9:29pm
15
That should work. If there isn’t anything in the logs, it’s quite possible there is some kind of error occurring in that method (or one that it calls). Or, it’s trying to log something too large.
Someday I’m hoping that all errors will actually make it to the log. Preferably with line numbers.
625alex
June 17, 2014, 5:48pm
17
I was testing with this skeleton app, and “runIn” command dies randomly after a number of runs. Is this a known issue. Is it only happening in the simulator?
Also, if I update the app, the scheduler resumes, but it runs twice.
definition(
author: "Alex",
description: "test runIn",
preferences {
section("Title") {
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
myJob()
def myJob() {
log.debug "running my job"
runIn(10, myJob, [overwrite: false])
Dianoga
(Brian Steere)
June 17, 2014, 6:30pm
18
Not sure why it’s dying. It’s possible the log just isn’t updating anymore. One thing you could try if you want a function to run every 1 or more minutes is using schedule("0 * * * * ?", myJob) in your initialize function. (schedule isn’t allowed more than once per minute)
As for it running twice, try adding unschedule() to your updated function.
