I am very new to adding custom code to my SmartThings. I bought Everspring 814-2 to monitor my wine cellar. I managed to get the V3 code into my device type handler and at first just had battery % showing. Then I published a second version of the same device handler and removed the device and re-added it selecting Everspring 814. I updated the update time to 2 mins and now I am seeing temperature and Humidity. I suspect because I did not change the reporting time from 120 mins everything was fine the first time I installed it, but now I am not getting the battery %. Also, is anything suppose to happen when you click on “Configuration” on the display?
Finally, is there anyway to display Max and Min for temperature or Humidity on this app like is on the main display. BTW, is v3 the latest version?
I want to thank Larry very much for his efforts, I would not be able to use this device at all without his efforts!
I have it working fine now - after some fettling - but how does the notification of the Max or Min temps being reached ?
The scenario is if the max temperature is exceeded then momentarily close a fibaro relay switch - and if the min temperature is hit then momentarily close a different fibaro switch.
I’m going to use CORE to generate the ‘app’ and its being used to open/close some Velux windows based on the temperature in the room.
use shm custom monitoring to alert you of temps too high or too low… that is what i use… also as a second backup there are other smartapps you can use… The custom monitoring is the only portion of shm i use… I use my version of smartalarm for security.
Temp monitoring and alerting is done in smart apps where you options to alert you and do other activities, ie like close the house water valve etc are more powerfull, not in device handlers.
@Lgkahn thank your for this DH. I have a problem though I think and wanted to know if you knew what was going on. I have ST814: In configure timeout value = 30 set. I would assume that it means that the Temp and Humidity would be sent to smart things every 30 minutes regardless. This is not the case. Sometimes it takes hours for the Temp and Humidity to be reported. Any ideas?
@Lgkahn Thanks for the DTH, nice tweaks over the default DTH. Apologies for waking a dead thread! Anyhow, I recently acquired an ST814-2 and loaded the DTH up from your GitHub and noticed that there were a couple of errors that kept recurring in the log (plus the unit beeping, not sure why) due to:
a) ST Groovy assigning unset preferences to null instead of 0 (zero)
b) ST Groovy treating integers/numbers as strings instead of doing an implicit conversion
I’ve had the same issues myself when writing SmartApps and its annoying to say the least.
I’ve had to make these same sort of changes to my own code and its usually always for unrequired settings that don’t have a forced default - like I mentioned, annoying.
have anyone been able to get this working in the new mobile app so it doesnt just show “checking status” on the device tile. If so what are your edits. thanks
