Moving from Iris: help needed selecting new devices
Iris is going away. Your help selecting products to replace my current configuration is appreciated
Items still needed:
Thermostat
Siren
Range extender
What I have so far is …
Samsung SmartThings F-MN US-2 Home Monitoring Kit, White Hub, Window/door sensor, notion)
NETGEAR - Indoor/Outdoor Mount - Arlo & Arlo Pro Compatible - White
There’s a list of compatible devices in either app or you can look here https://www.smartthings.com/products
Also if you read through the forums you may find that some of your iris devices maybe compatible w/ Smartthings.
Welcome! :sunglasses:
You won’t need a separate range extender. For both zigbee and zwave, pretty much any mains powered devices except smoke sensors will automatically act as repeaters anyway. The most popular are usually light switches or plug-in pocket sockets, but also in wall micros, plug-in sensors, plug-in sirens, etc.
Battery operated devices do not usually act as repeaters.
Z wave repeats only for Z wave and zigbee repeats only for zigbee, so just take that into account when deciding which devices go where.
For more information, see post 11 in the following thread (the topic title is a clickable link), then go back up to the top of that thread and read the whole thing.
For a Z-Wave thermostat, the GoControl/Linear/RTC CT-xxx series thermostats are great, cheap, highly configurable and easy to integrate. The ZTS-500 series thermostats are also good but more expensive. You can also look at Nest, EcoBee and other utility specific integrations.
For Sirens, I would recommend the (Lowes Utilitech also sold as GoControl and some other brand names I believe) Siren, it’s one the best and has great battery life. You can also look at the Vision Siren that you can buy at www.thesmartesthouse.com
Range Extenders, JD has given you a great guide to check out.
Thank you for all this information
