Is there anything out there that will tell me if a car door has opened that integrates with the system or can I use some existing to do this that isn’t awkward and bulky?
Will the accelerometer in the current open/close sensor do the trick or is there something better?
Hue has an IFTTT channel. As does Automatic and also SmartThings. But it can be a 15 minute polling delay, which might not work depending on the use case.
tgauchat
5
I presume this is only for detection while the car is in range of your hub?
Does the door have a built in safety / courtesy light? I’m thinking that we can figure out a way to watch for current flow there…
I’m currently using the ecolink door open sensors for this. It’s a touch awkward but not too bad. I have it mounted low on the door near the hinge so it’s pretty out of the way. Response is instant.
