Mimolite input capability?
You can use this device type to get it to work as a contact sensor:
You could also use any number of the cheaper zwave door/window sensors that have terminals for contact switches. Ecolink Door/Window Sensor is one, but there are many others.
Door/window sensors tend to be much cheaper than the MIMOlite if you don’t need the MIMOlite’s output.
