Using the SmartThings mDNS library to discover LAN devices
Here is a function I use in my edge driver discovery handlers to discovery LAN devices using mDNS.
1. Finding Devices
This code snippet uses mDNS to find LAN devices, with a name containing “Shelly” , which publicise a service called “http”.
local numberOfDiscoveredDevices, discoveredDevices = discoverDevices( "Shelly", "http")
E.g. In my network mDNS discovered 10 devices publicising the “http” service.
- ShellyPlus1-441793A9C238
- everything-presence-st-d53394
- Sky Q Mini1478
- everything-presence-one-e016bc
- E415F65056F5@mysimplelink
- espNeostatHubBridge
- ShellyPlus1-441793A90660
- Sky Q 2TB Box2919
- Sky Q Mini9573
- Samsung M288x Series (SEC842519107403)
Of which two (1 & 7) matched my name criteria. So details of these two devices were returned.
Tip. watch out for devices with a “-” in their name. The minus sign needs an escape character e.g. everything%-presence in the deviceName.
The returned information can then be used to create two Smartthings devices.
2. discoverDevices function
local mdns = requires('st.mdns')
local function discoverDevices( deviceName, service)
local serviceType = "_" .. service .. "._tcp"
local domain = "local"
local discoveredDevices = {}
local i = 0
local discoveryResponses = mdns.discover(serviceType, domain) or {}
log.info('*** mDNS discovered ' .. #discoveryResponses.found .. " devices")
for idx, answer in ipairs(discoveryResponses.found) do
if string.find(answer.service_info.name, deviceName) then
log.info('*** Discovered a ' .. deviceName .. ' device: ', idx, answer.service_info.name, answer.host_info.address, answer.host_info.port)
i = i+1
discoveredDevices[i] = {
name = answer.service_info.name,
ipAddress = answer.host_info.address,
port = answer.host_info.port
end
end
return i, discoveredDevices
end
