Hello, today I get my smart things kit and I purchased an outlet and a water sensor (among other things). Basically how can I get the outlet to power on when water is detected with the sensor? If you are wondering, the outlet will energize a normally open water shutoff
In ST app go to MarketPlace, select SmartApp Tab, select Safety and security,Scroll down the list and look for “Dry the Wetspot”
Thank you for the reply, I must have missed it. I currently am using “Dry the Wet Spot” but once the water has drained the valve will open up again. I am looking for something that will shut the valve until I open it or dismiss the alert.
