Unfortunately this doesn’t work for me. I need something to work with Motion Sensors. Once you walk in and the lights turn on, before I can even get to the switch so the original default state is “off”
Looking for a better motion-controlled light app
It is a little challenging to determine, when you finally reach the light switch, since the lights have already turned on, pressing the switch means “turn off”.
Would you consider using another switch like an Aeon Minimote or Enerwave 7-Button? Possibly some Virtual Switch devices all working together for this functionality.
Or some code with various timings to give you time to tap the switch, but it would have to be Lutron patent compatible, I think, so as to immediately report the tap and turn the light back on…
Problem is that SmartThings scheduling of short term events isn’t very accurate at the moment.
I see what you’re saying now. The problem is that “Turn off when there is no motion” only works when there has been motion. So yes, if you turn on a light by some means other than motion, it will not turn off with that logic, whether that logic is in “lights follow me” or any other motion based smart app.
So you will have decide what OTHER logic you want to be involved in turning off those lights besides motion. The most obvious choice is time, i.e. “turn off after a period of time”. Note that you can have multiple apps controlling the same lights. So you can keep the motion control that works, and add the time turn-off. Now, this is where it can get tricky: Suppose you turn the light on with the mobile app, and your time thing says turn it off in 5 minutes. Suppose during those five minutes you trip the motion sensor, and are actually in that space actively. The light will still turn off in 5 minutes, even if there is still motion. If that’s not what you want to have happen, you would have to write a smart app to combine the two forms of logic for turning off the light (i.e., turn off after 5 minutes or there is no motion, whichever is later).
Make sense? Easy app to write, or easy to modify one of the template apps.
There is one other method of doing this that I use, and that’s a “master off” concept. I have some lights that are turned on by motion and then off when there is no motion for x minutes. In that same area are some other lights not turned on by motion, just turned on with the switch (a z-wave switch). I have it set up so that when the main set of motion controlled lights turn off, by whatever mechanism, the other lights get turned off at the same time — sort of an “off with me” logic.
Of course, all of this depends on the layout of your lighting, switches, motions, flow in the home, etc. etc.
I want the main kitchen lights to turn on with motion and turn off with no motion after 2 minutes. BUT I want to be able to leave them Always On by pressing the switch, bypassing the motion commands.
If we’re cooking, standing by the stove or sitting at the table reading, it could be still enough for the lights to turn off and with the delays of SmartThings operation it might be a minute or so before the lights are back on which is annoying and unsafe.
You will eventually be able to do this once microlocation devices exist and ST uses them. Like iBeacons or Samsung’s Placedge, these won’t require movement to be detected, solving all the use cases you mention above, plus a personal concern for me, the person who falls or passes out and takes several minutes before they start moving again.
Microlocation will probably initially require a wearable for presence to be detected, although ultimately it may do things like listen for heartbeats.
My guess is we’ll have practical in home microlocation based on wearables or at least cellphones by summer 2016. (Apple’s HomeKit clearly assumes they’re coming.) and since this helps make the case for smart watches, I think Samsung may be on a similar timeline.
In the meantime…I personally like motion detectors to turn things on, but I don’t use them in residential installations to turn lights off unless a) the sensor is being used as a touchless switch intentionally triggered with a hand wave, b) they’re used to control a group, but at least one light is not automatically turned off.
My personal feeling from an engineering standpoint is just that motion sensors are usually the wrong technology to use for ongoing occupancy indicators. It’s always going to be hard to get the pattern just right.
But I do think the solution with a different technology is coming. Just not for a year or so.
FWIW…
It sounds like your motion coverage is inadequate to the task, if you are in there and the lights are turning off. A couple of things you could do: (1) add another motion sensor to get better coverage, (2) increase the time before it turns off from no motion so that there is a higher probability it sees motion before it turns off, (3) use code like the app I originally referenced above with a Minimote remote control (in this case, pressing a button on the Minimote could disable all of the motion-off logic).
Your case 3) above will still run into the “tricky” issue from your previous post, won’t it?
I can’t kill the previously triggered off instruction once the sensor detected the initial the motion, can I?
So:
Person walks into kitchen, tripping motion sensor, running app that turns lights on and schedules lights off after 5 minutes of no motion.
Person sits at kitchen table and starts reading.
Person hits button on minimote to leave lights on.
After 5 minutes of no motion have gone by, won’t lights still go off?
It depends on how you do the disabling. I clearly didn’t understand his use case / problem at first. Another, possibly superior way to do it is to use a mode. Pushing the Minimote button could cause a mode change to “Cooking”. If the “turn off on no motion” is mode restricted to other modes, just not Cooking, then the light won’t turn off. Forget the “turn off after a period of time” bit. These are kludges. As you pointed out, the source of the problem is relying on motion to turn things off.
I do that (no motion turns things off) in a dozen spaces in my house, and for the most part it works perfectly. Funny one is my office, where I have a motion sensor about 3 feet from where I sit pointed right at me. You are absolutely correct that if I sit here absorbed in something, reading, writing, anything without much motion, the lights sometimes turn off on me. Of course, sitting on my desk is a Minimote. It’s used to turn on a ceiling fan, or to turn the lights back on. This happens very infrequently, and it would happen a lot less if I increased the time from 2 minutes to something higher. These aren’t perfect solutions!
Honestly, the use of a mode is completely out of the question. Modes, IMHO, are a disaster. It’s a lot of people’s “go to” workaround instead of having legitimate solutions for where SmartThings comes up woefully short, the problem is that every mode based SmartApp needs to be entirely rethought when a new mode is introduced. If I start creating modes for cooking or other such entirely specific things, it will just compound the problem. Switching from one mode to another doesn’t always work seamlessly and especially not when you aren’t in the correct mode to start with. For example, if I go out with my wife and we come home after the house is scheduled to move from AWAY to NIGHT, it switches to HOME so I have to manually take out the APP and switch it to NIGHT.
My whole purpose of automating is to remove switches and buttons and apps. I want the house to behave the way I need it to behave when I need to behave that way without constant interaction. I want to walk into the kitchen and get a snack and come back to my computer without touching any switches. I also want to leave the lights on when I’m quietly reading without them going off on me.
As for the motion area, it detects just fine, but not if we’re still or walking in and out of the room while doing other things. Or if we’re entertaining we’d prefer to leave the light on so as not to disorient guests. This is just one of many, many areas where SmartThings has exceptionally let me down. I’ve spent over $2k in automation and half of the simple tasks I’ve thought should be common sense, have been impossible to do without a degree in software engineering or in some cases, just plain impossible.
I think microlocation is a bit pie in the sky. WAY too many variables involved to make it work well and be affordable. Not to mention the inconvenience of things not working properly because you don’t have your iWatch or Samsung Gear on to walk from one room to the other. Not to mention guests. I’ll wait and see, but I’m thinking it’s 3-5 years off from being really viable as an affordable consumer DIY product.
I agree (This is because SmartThings only has one mode variable… Only 1 mode active at a time, instead of a way to have a mode for home/away, night/day, and regular/vacation, etc…).
The workaround for having only one global mode variable, is to use Virtual Switches (or Virtual Devices of some other sensible type).
A Device Instance allows you to communicate arbitrarily between SmartApps (ie, if one SmartApp is for motion on and off, and another SmartApp is watching for lightswitch events, the first can check a Virtual Device set by the other, and vice versa).
You can make it less (or more) convoluted, possibly by using Virtual Devices that are an abstraction layer specific to the Physical Devices. In other words, create a Virtual Motion Sensor and have SmartApps subscribe to it instead of the Physical one.
The Virtual Motion Sensor’s status is set by a management SmartApp that watches the Physical one and takes other information into account (ie, has a switch been toggled recently then ignore lack of motion…). Lots of power.
It’s a shame that you have discarded one of the most powerful mechanisms in ST because you think it’s a “disaster”. The problems you describe with modes are all easily solved.
Not every automation challenge is easily solved. Expecting something as simple as a motion sensor to work in two completely different ways all on its own is, how to be tactful, not the most thoughtful reaction.
What @tgauchat describes above is a variation of the original link I gave you. There are solutions to what you want if you choose to find them. Good luck.
I think virtual switches would be a great solution for many ST use cases if there were a way in the official ST mobile app to create one without touching the IDE. Just a straight binary on/off switch. There would be so much non coders could do with this.
There is a community app recently published by @baldeagle072 that spawns virtual switches, i.e. on/off virtual devices. Once that app is installed, one would not need to use the IDE to create new virtual switches. See this thread: Feature Request - On/Off Button Tile - why can't you install it from the ST App itself
I’m really excited about this!
Unfortunately, adding a million different modes simply doesn’t solve the problem as it compounds the problem by altering the behavior of every other mode based app. Secondly, I can only run each app once for a single device. I can’t change the parameters of the app for each mode, yet another problem of modes.
As for my expectations, expecting a motion sensor to turn on and off a light is one of the most basic automation uses there is. Expecting the hardwired switch to be able to override that, yes, is my, and as far as I can tell many people’s, expectation. I’m not asking the motion sensor to behave in multiple ways, just that the hardware should trump the software. The switch is another input, just like the app. Yet once I program it to turn off with no motion there is NO WAY short of a mode change (which creates a myriad of other complications I don’t want to go through every time I add a single feature to my home) to prevent it from turning off. Not in the app (short of deleting the SmartApp) or physically. I am not a software engineer so I can’t really code a terrifically complicated piece of software. But using your code (which I DO plan on using for my contact sensor on the door) and needing a remote control to activate a virtual device for the kitchen lights and having to press the remote before I even enter the room is silly and a band aid on an axe wound. When caring for two newborns I am not going to be fumbling around trying to find a remote the size of a pack of gum so I can go in the kitchen without any hassle. These types of awkward, unintuitive behaviors might be acceptable for some, but they aren’t for me as my home needs to be easily occupied by my in-laws who are not technically minded and will expect it to operate the same as their own home. In my mind, automation should ADD features, not remove them.
It would help if you would describe in more detail precisely what you want to have happen that you can’t make happen.
Modes are one way to do things like this, not the only way. I would offer the observation that if there are two different things you want to happen (lights on with motion then off after no motion, and lights stay on), there will have to be some manual intervention to cause the change. That can be a switch. Obviously, code written to suppress motion BEFORE it has triggered won’t work. So what manual thing do you want to do to push the system into its second form?
I had a house guest (with two babies), who wanted to prevent a hall light from going on with motion, so as to not have the light awaken the babies. Simple app allowed this: if the light was turned off with the switch, it would stay off until it was on again and allowed to turn off from the no-motion turn-off. That was a variation on a theme. Sounds like you need another variation on the same theme.
I’m new to the Community. I have a related question that I’m sure is a stupid one, but I can’t find an answer on previous posts. I’m looking for a functional Vacancy Sensor. To be clear, I differentiate this from an Occupancy Sensor, as follows: An occupancy sensor detects motion and turns on a light (or whatever), and then turns it off if no motion is detected after a set period of time. A vacancy sensor does not turn on the light when motion is detected the first time, but if the light is manually turned on, it will automatically turn off if no motion is detected after a period of time.
I’m currently using SmartLighting to do this, which works correctly, as described above, if I only enable the “turn light off when motion is not detected” options. What is missing is a way to re-trigger the light to turn back on if it incorrectly turns off when I’m still in the room. With a standard “non-smart” Vacancy Sensor light switch, there is a short period of time after the light automatically turns off, when you can wave your arms around, and it turns back on. I can’t figure out how to make this happen with SmartThings.
To clarify, if I set a light to both automatically turn on with motion, and off when motion stops (a classic Occupancy Sensor function), then the problem I described above is fixed (i.e. if the light turns off, leaving me in the dark, I can wave my arms and the motion is detected and turns the lights back on). So, the problem is not a lag in my system or my sensors. It’s just that the app doesn’t allow for this short time to re-trigger the lights when it accidentally turns off.
I can’t believe I’m the first person to want this function, but I can’t find it. Can you help?
None of this is possible with the built-in functions of SmartLighting. However, WebCoRE can do everything you’ve described:
Using WebCoRE I have my lights set to “flash” once to warn me that they are about to turn off.
