Bundle is on sale for $287.58.
Logitech Harmony Elite + All-New Echo Dot (2nd Generation) https://www.amazon.com/dp/B01MG1YVYP/ref=cm_sw_r_cp_api_O0ihyb1TXG394
I want one of these remotes sooo bad, but I am having trouble justifying it. Would love for someone to talk me into it.
I got one, I was hesitant to upgrade from the harmony one but I’m glad I did. Now that there’s alexa to harmony integration with a dot next to the couch you can change channels by voice. Not a necessity but…
From SmartThings you can run an activity, right? Have you done anything with CoRE? Meaning can CoRE kick off an activity?
You can run your activities from ST but I haven’t done anything with CORE yet.
Yes, CoRE can do this
Ok, I give. Ordered.
It’ll make you feel good.
I have been able to use CoRE by turning on the switch that gets added by integrating Harmony. However trying to use Using Harmony, Start Activity “Activity Name”, I cannot get it to work. I get some error like this is blacklisted at Harmony. Are you able to use start activity? Also are you able to save attribute currentActivity to a variable and load attribute currentActivity from a variable?
Not sure if you did this yet but in your list of things in ST you have to delete the ( harmony activity) that’s in paratheses after the activity.
How do you go about detecting an activity is ran via core?
Yes I have deleted the [Harmony Activity] that was added and tried starting both, Just the activity and and the activity with [Harmony Activity]
