I’m attempting to look for a Lighting smartapp that uses multiple criteria. For my case:
Garage Lights on IF
Presence Detected AND
Garage Door Opens AND
Time after 7PM or Sunset (either one will work)
It would be nice to set a timer as well for the lights to be on and for the lights to turn off.
The default routines uses an OR I believe. and the SmartLighting can do 1 & 3 but not when Contacts Open/Close. Hopefully someone could just add the code “Only when contacts are”
Please let me know if anyone has worked on this already. I tried putting some code together but it’s mainly me meshing other templates together and trying to make it work.
Yeah I thought about this one. The only thing I was hoping for is that additional feature of turning off at a certain amount of time. Thanks for sharing.
Turning off after a certain amount of time is easy to add to your list of conditions with WebCore. WebCore is essentially a scripting language for SmartThings and is designed for complex conditionals. See the FAQ above for more information.
Off after time, use the power allowance setting in the smart lighting. I have a general one the covers multiple lights and device which turns them off after 10min i use it on garage lights and outside lights
