Lighting Scene Control?
I have been waiting to see if SmartThings is going to update their app to allow for more individual dimming settings on lights that are linked to one scene. Example, I have 6 different lights and want lights 1&2 to be at 50% lights 3&4 at 75% and 5&6 to be at 90% but connected to one scene.
Maybe Rule Machine can do what you want.
Rule Machine supports two different dimmer levels per Rule, so it can’t quite reach to what he wants in a single rule. Could use two rules, with same conditions, to get 4 dimmer levels.
I am also looking for a solution. Did you happen to find anything?
You could give superState a shot.
If it works for you great, if not there are other scene capture utilities out there as well.
This all sounds overly complex when the Smartthings app could easily do scenes natively: all we need is dim level per light when creating Routines. Simple enough and straightforward.
Exactly as @devedsmith is saying - when you are setting the routine, there should be level per each light. And I also want to change my bulbs colors or ambiente if it supports it, or set some HUE scene. For example I want to have all my ambiente bulb yellowish tint after 7pm - its more relaxing for eyes.
“easily”? if anything was easy they would have added entry and exit delays on Smart Home Monitor ages ago. :confounded:
