This is with 2 bulbs, and it looped. I was able to stop the loop by pressing down on the dimmer.
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:42 PM: info [type:level, value:28]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:42 PM: debug description is read attr - raw: 9F550100080800002047, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 47
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:41 PM: debug dimmer value is 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:41 PM: trace descMap : [raw:4F8C0300080800002047, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:47]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:40 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:40 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:40 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: info [type:level, value:28]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: debug description is read attr - raw: 9F550100080800002048, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 48
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:39 PM: debug dimmer value is 78
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:39 PM: trace descMap : [raw:4F8C03000808000020C6, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:c6]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:39 PM: info [type:switch, value:on]
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:37 PM: info switchSetLevelHandler Event: 28
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:38 PM: trace setLevel(28)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:38 PM: trace setLevel(28)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:38 PM: debug dimmer value is 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:38 PM: trace descMap : [raw:4F8C0300080800002047, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:47]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:37 PM: info [type:level, value:28]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:37 PM: debug description is read attr - raw: 9F550100080800002047, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 47
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:36 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:37 PM: trace setLevel(13)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:37 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:37 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:37 PM: trace setLevel(13)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:37 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:37 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: info [type:level, value:13]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: debug description is read attr - raw: 9F550100080800002022, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 22
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:36 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:36 PM: debug dimmer value is 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:36 PM: trace descMap : [raw:4F8C0300080800002047, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:47]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:35 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:35 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:34 PM: debug dimmer value is 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:34 PM: trace descMap : [raw:4F8C0300080800002047, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:47]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:34 PM: debug dimmer value is 56
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:34 PM: trace descMap : [raw:4F8C030008080000208E, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:8e]
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:33 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:33 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:33 PM: trace setLevel(56)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: info [type:level, value:56]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: debug description is read attr - raw: 9F55010008080000208F, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 8f
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:33 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:32 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:32 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:31 PM: debug dimmer value is 56
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:31 PM: trace descMap : [raw:4F8C030008080000208E, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:8e]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:30 PM: debug dimmer value is 78
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:30 PM: trace descMap : [raw:4F8C03000808000020C6, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:c6]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: info [type:level, value:78]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:30 PM: debug description is read attr - raw: 9F5501000808000020C6, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: c6
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:29 PM: debug dimmer value is 34
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:29 PM: trace descMap : [raw:4F8C0300080800002056, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:56]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:28 PM: debug dimmer value is 34
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:28 PM: trace descMap : [raw:4F8C0300080800002056, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:56]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:28 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:28 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:27 PM: info switchSetLevelHandler Event: 78
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:27 PM: trace setLevel(78)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:27 PM: trace setLevel(78)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: info [type:level, value:78]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:27 PM: debug description is read attr - raw: 9F5501000808000020C7, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: c7
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:27 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:27 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:26 PM: debug dimmer value is 34
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:26 PM: trace descMap : [raw:4F8C0300080800002056, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:56]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:25 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:25 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:25 PM: debug dimmer value is 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:25 PM: trace descMap : [raw:4F8C0300080800002047, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:47]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:23 PM: info switchSetLevelHandler Event: 28
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:24 PM: trace setLevel(28)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: info [type:level, value:28]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:24 PM: debug description is read attr - raw: 9F550100080800002047, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 47
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:24 PM: debug dimmer value is 78
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:24 PM: trace descMap : [raw:4F8C03000808000020C6, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:c6]
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:23 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:24 PM: trace setLevel(13)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:24 PM: trace setLevel(28)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:23 PM: trace setLevel(28)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:23 PM: trace setLevel(28)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:22 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:23 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:21 PM: info switchSetLevelHandler Event: 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:23 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:22 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:23 PM: trace setLevel(56)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:22 PM: info switchSetLevelHandler Event: 28
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:23 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:23 PM: debug dimmer value is 56
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:23 PM: trace descMap : [raw:4F8C030008080000208E, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:8e]
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:21 PM: info switchSetLevelHandler Event: 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:22 PM: trace setLevel(28)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:22 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:22 PM: trace setLevel(13)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:22 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:21 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:22 PM: trace setLevel(56)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:22 PM: info [type:level, value:56]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:22 PM: debug description is read attr - raw: 9F55010008080000208F, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 8f
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:21 PM: info switchSetLevelHandler Event: 78
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:22 PM: trace setLevel(78)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:22 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:22 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:22 PM: trace setLevel(78)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:20 PM: info switchSetLevelHandler Event: 28
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:22 PM: trace setLevel(28)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:21 PM: trace setLevel(78)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:21 PM: info switchSetLevelHandler Event: 34
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:21 PM: trace setLevel(34)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:21 PM: trace setLevel(34)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:21 PM: trace setLevel(78)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:20 PM: info switchSetLevelHandler Event: 34
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:21 PM: trace setLevel(28)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:20 PM: info switchSetLevelHandler Event: 13
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: info [type:level, value:13]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:21 PM: debug description is read attr - raw: 9F550100080800002021, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 21
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:21 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:20 PM: info switchSetLevelHandler Event: 78
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:20 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:21 PM: trace setLevel(56)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:18 PM: info switchSetLevelHandler Event: 34
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:21 PM: trace setLevel(13)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:21 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:21 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:19 PM: info switchSetLevelHandler Event: 78
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:20 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:20 PM: trace setLevel(34)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:20 PM: trace setLevel(78)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:19 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:20 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:19 PM: info switchSetLevelHandler Event: 28
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:20 PM: trace setLevel(28)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:20 PM: trace setLevel(28)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:18 PM: info switchSetLevelHandler Event: 78
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:20 PM: trace setLevel(78)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:20 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:19 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:19 PM: trace setLevel(56)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:18 PM: info switchSetLevelHandler Event: 56
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:19 PM: debug Parse returned Dr1 switch is off
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:19 PM: trace setLevel(78)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:19 PM: trace setLevel(56)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:17 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:19 PM: trace setLevel(13)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:19 PM: debug Parse returned Dr2 switch is off
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:19 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:19 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:19 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:19 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:19 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:18 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:18 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:17 PM: info switchSetLevelHandler Event: 78
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:16 PM: info switchOnHandler Event: on
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:18 PM: debug Parse returned Dr2 switch is off
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:18 PM: trace setLevel(78)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:18 PM: debug on()
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: trace setLevel(56)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:17 PM: info switchSetLevelHandler Event: 34
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:18 PM: trace setLevel(34)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:17 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:18 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: trace setLevel(78)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: trace setLevel(34)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: debug on()
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: info [type:level, value:13]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: debug description is read attr - raw: 9F550100080800002021, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 21
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: debug dimmer value is 56
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:18 PM: trace descMap : [raw:4F8C030008080000208E, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:8e]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:18 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:15 PM: info switchSetLevelHandler Event: 34
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:17 PM: trace setLevel(34)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:16 PM: info switchSetLevelHandler Event: 13
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:17 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:15 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:17 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:17 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:17 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:17 PM: trace setLevel(13)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:15 PM: info switchoffHandler Event: off
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:16 PM: debug off()
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:16 PM: trace setLevel(34)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:14 PM: info switchSetLevelHandler Event: 78
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:16 PM: trace setLevel(78)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:16 PM: debug off()
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:16 PM: trace setLevel(56)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:14 PM: info switchOnHandler Event: on
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:16 PM: trace setLevel(13)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:16 PM: debug on()
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:16 PM: debug dimmer value is 13
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:16 PM: trace descMap : [raw:4F8C0300080800002021, dni:4F8C, endpoint:03, cluster:0008, size:08, attrId:0000, encoding:20, value:21]
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:15 PM: trace setLevel(13)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:15 PM: debug on()
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:15 PM: trace setLevel(78)
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:14 PM: info switchSetLevelHandler Event: 13
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:13 PM: info switchSetLevelHandler Event: 34
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:15 PM: trace setLevel(13)
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:15 PM: trace setLevel(34)
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: info [type:switch, value:on]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: debug description is catchall: 0104 0006 01 01 0140 00 9F55 00 00 0000 0B 01 0100
f4b9be91-38f0-4c24-9e99-6b4734d0f0f5 5:27:15 PM: info [name:level, value:100, type:level]
f4b9be91-38f0-4c24-9e99-6b4734d0f0f5 5:27:15 PM: debug description is read attr - raw: 368401000808000020FE, dni: 3684, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fe
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: info Dining room Dimmer updates: level updated successfully
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: info [type:update, value:level updated successfully]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: debug description is catchall: 0104 0008 01 01 0140 00 9F55 00 00 0000 0B 01 0400
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: info [type:level, value:34]
23eed4cd-40e3-439b-9ac2-4d758c279acc 5:27:15 PM: debug description is read attr - raw: 9F550100080800002057, dni: 9F55, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: 57
d0064f3a-18b8-4649-9cbd-89fb0c10c55a 5:27:12 PM: info switchSetLevelHandler Event: 56
9e2d0f58-cabb-44ff-b8d7-c82dd7e56625 5:27:15 PM: trace setLevel(56)
92a7adeb-44cc-4cdf-9571-9d1e210f463b 5:27:15 PM: debug dimmer value is 56
