Leaksmart Water Sensor
If the product is “Zigbee Certified” as the box states, shouldn’t it show up on http://www.zigbee.org/zigbee-products-2/
I wonder if their thing is a rebranded version of something on this site… These things are all documented from what I can tell.
OK, major find. I get a response from the sensor on alarm for cluster 0B02. So, take my code snippet from above with cluster 0x500 and substitute 0x0B02 and get the alarm. Now to parse the data:
Alarm state:
B02 Cluster Data: [1, 129, 17, 0]
Clear state:
B02 Cluster Data: [1, 129, 1, 0]
This code works! Haven’t figured out the refresh, it’s telling me cluster 0x0B02 attribute 0x0000 is not supported, but the alarm is sending back on the report:
  • Copyright 2016 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not
  • use this file except in compliance with the License. You may obtain a copy
  • of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software
  • distributed under the License is distributed on an “AS IS” BASIS, WITHOUT
  • WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
  • License for the specific language governing permissions and limitations
  • under the License.
metadata {
definition (name: “leakSmart Moisture Sensor”,namespace: “smartthings”, author: “SmartThings”, category: “C2”) {
capability "Configuration"
capability "Battery"
capability "Refresh"
capability "Temperature Measurement"
capability “Water Sensor”
    fingerprint inClusters: "0000,0001,0003,0020,0402,0B02,FC02", outClusters: "0003,0019", manufacturer: "Waxman", model: "leakSmartv2", deviceJoinName: "LeakSmart Sensor"
simulator {
preferences {
    section {
        image(name: 'educationalcontent', multiple: true, images: [
			"http://cdn.device-gse.smartthings.com/Moisture/Moisture1.png",
			"http://cdn.device-gse.smartthings.com/Moisture/Moisture2.png",
			"http://cdn.device-gse.smartthings.com/Moisture/Moisture3.png"
    section {
        input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
        input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
tiles(scale: 2) {
    multiAttributeTile(name:"water", type: "generic", width: 6, height: 4){
        tileAttribute ("device.water", key: "PRIMARY_CONTROL") {
            attributeState "dry", label: "Dry", icon:"st.alarm.water.dry", backgroundColor:"#ffffff"
            attributeState "wet", label: "Wet", icon:"st.alarm.water.wet", backgroundColor:"#53a7c0"
    valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
        state "temperature", label:'${currentValue}°',
        backgroundColors:[
            [value: 31, color: "#153591"],
        [value: 44, color: "#1e9cbb"],
        [value: 59, color: "#90d2a7"],
        [value: 74, color: "#44b621"],
        [value: 84, color: "#f1d801"],
        [value: 95, color: "#d04e00"],
        [value: 96, color: "#bc2323"]
    valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
        state "battery", label:'${currentValue}% battery', unit:""
    standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
        state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
    main (["water", "temperature"])
    details(["water", "temperature", "battery", "refresh"])
log.debug “description: $description”
Map map = [:]
if (description?.startsWith(‘catchall:’)) {
map = parseCatchAllMessage(description)
else if (description?.startsWith(‘read attr -’)) {
map = parseReportAttributeMessage(description)
else if (description?.startsWith('temperature: ')) {
map = parseCustomMessage(description)
else if (description?.startsWith(‘zone status’)) {
log.debug "ZONE STATUS"
map = parseIasMessage(description)
    log.debug "Parse returned $map"
def result = map ? createEvent(map) : null
if (description?.startsWith(‘enroll request’)) {
List cmds = enrollResponse()
log.debug "enroll response: ${cmds}"
result = cmds?.collect { new physicalgraph.device.HubAction(it) }
return result
private Map parseCatchAllMessage(String description) {
Map resultMap = [:]
def cluster = zigbee.parse(description)
if (shouldProcessMessage(cluster)) {
switch(cluster.clusterId) {
case 0x0001:
log.debug "001 Cluster Data: ${cluster.data}"
resultMap = getBatteryResult(cluster.data.last())
break
    case 0x0402:
       // temp is last 2 data values. reverse to swap endian
    	log.debug "402 Cluster Data: ${cluster.data}"
        String temp = cluster.data[-2..-1].reverse().collect { cluster.hex1(it) }.join()
       def value = getTemperature(temp)
        resultMap = getTemperatureResult(value)
        break
    case 0x0B02:
    	log.debug "B02 Cluster Data: ${cluster.data}"
        String temp = cluster.data[2];
        log.debug "B02 temp data ${temp}"
        return parseAlarmCode(temp)
		break
else {
log.debug “Did not process message ${cluster}”
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
// 0x07 is bind message
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
cluster.command == 0x07 ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
private Map parseReportAttributeMessage(String description) {
Map descMap = (description - “read attr - “).split(”,”).inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
log.debug “Desc Map: $descMap”
Map resultMap = [:]
if (descMap.cluster == “0402” && descMap.attrId == “0000”) {
def value = getTemperature(descMap.value)
else if (descMap.cluster == “0001” && descMap.attrId == “0020”) {
resultMap = getBatteryResult(Integer.parseInt(descMap.value, 16))
return resultMap
private Map parseCustomMessage(String description) {
Map resultMap = [:]
def value = zigbee.parseHATemperatureValue(description, "temperature: ", getTemperatureScale())
return resultMap
private Map parseIasMessage(String description) {
List parsedMsg = description.split(’ ')
String msgCode = parsedMsg[2]
log.debug "Parse IAS MESSAGE"
log.debug msgCode
Map resultMap = [:]
switch(msgCode) {
case ‘0x0020’: // Closed/No Motion/Dry
resultMap = getMoistureResult(‘dry’)
break
case '0x0021': // Open/Motion/Wet
    resultMap = getMoistureResult('wet')
    break
case '0x0022': // Tamper Alarm
    break
case '0x0023': // Battery Alarm
    break
case '0x0024': // Supervision Report
    log.debug 'dry with tamper alarm'
    resultMap = getMoistureResult('dry')
    break
case '0x0025': // Restore Report
    log.debug 'water with tamper alarm'
    break
case '0x0026': // Trouble/Failure
    break
case '0x0028': // Test Mode
    break
return resultMap
def getTemperature(value) {
def celsius = Integer.parseInt(value, 16).shortValue() / 100
if(getTemperatureScale() == “C”){
return celsius
} else {
return celsiusToFahrenheit(celsius) as Integer
private Map getBatteryResult(rawValue) {
log.debug "Battery rawValue = ${rawValue}"
def linkText = getLinkText(device)
def result = [
value: '--',
translatable: true
def volts = rawValue / 10
if (rawValue == 0 || rawValue == 255) {}
else {
    if (volts > 4.5) {
        result.value = 100
        result.descriptionText = "{{ device.displayName }} battery has too much power: (> 3.5) volts."
    else {
        if (device.getDataValue("manufacturer") == "SmartThings") {
            volts = rawValue // For the batteryMap to work the key needs to be an int
            def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
							  22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
            def minVolts = 15
            def maxVolts = 28
            if (volts < minVolts)
                volts = minVolts
            else if (volts > maxVolts)
                volts = maxVolts
            def pct = batteryMap[volts]
            if (pct != null) {
                result.value = pct
                result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
        else {
            def minVolts = 2.1
            def maxVolts = 4.5
            def pct = (volts - minVolts) / (maxVolts - minVolts)
            result.value = Math.min(100, (int) pct * 100)
return result
private Map getTemperatureResult(value) {
log.debug 'TEMP’
if (tempOffset) {
def offset = tempOffset as int
def v = value as int
value = v + offset
def descriptionText
if ( temperatureScale == ‘C’ )
descriptionText = '{{ device.displayName }} was {{ value }}°C’
else
descriptionText = ‘{{ device.displayName }} was {{ value }}°F’
return [
value: value,
descriptionText: descriptionText,
translatable: true
private Map getMoistureResult(value) {
log.debug "water"
def descriptionText
if ( value == “wet” )
descriptionText = '{{ device.displayName }} is wet’
else
descriptionText = '{{ device.displayName }} is dry’
return [
value: value,
translatable: true
private Map parseAlarmCode(value) {
log.debug “parse alarm code ${value}”
Map resultMap = [:]
switch(value) {
    case "1": // Closed/No Motion/Dry
    	log.debug "dry"
        break
    case "17": // Open/Motion/Wet
    	log.debug "wet"
        break
return resultMap
def refresh() {
log.debug "Refreshing"
def refreshCmds = [
zigbee.readAttribute(0x0402, 0x0000), “delay 200”,
zigbee.readAttribute(0x0001, 0x0020), “delay 200”,
zigbee.readAttribute(0x0b02, 0x0000), “delay 200”
//zigbee.readAttribute(0xFC02, 0x0001), “delay 200”
// “st rattr 0x${device.deviceNetworkId} 1 0x402 0”, “delay 200”,
// “st rattr 0x${device.deviceNetworkId} 1 1 0x20”, “delay 200”,
return refreshCmds + enrollResponse()
def configure() {
sendEvent(name: “checkInterval”, value: 7200, displayed: true)
String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
log.debug "Configuring Reporting, IAS CIE, and Bindings."
def configCmds = [
// “zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}”, “delay 200”,
// “send 0x${device.deviceNetworkId} 1 1”, “delay 500”,
	zigbee.configureReporting(0x0001, 0x0020, 0x20, 30, 21600, 0x01), "delay 500",
  	zigbee.configureReporting(0x0402, 0x0000, 0x29, 30, 3600, 0x0064), "delay 500",
    zigbee.configureReporting(0x0b02, 0x0000, 0x10, 0, 3600, null), "delay 500"
// “zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 1 {${device.zigbeeId}} {}”, “delay 500”,
// “zcl global send-me-a-report 1 0x20 0x20 30 21600 {01}”, //checkin time 6 hrs
// “zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 0x402 {${device.zigbeeId}} {}”, “delay 500”,
// “zcl global send-me-a-report 0x402 0 0x29 30 3600 {6400}”,
def tmp = zigbee.configureReporting(0x0500, 0x0000, 0x10, 0, 3600, null)
log.debug “Command for 500 report: ${tmp}”
return configCmds + refresh() // send refresh cmds as part of config
def enrollResponse() {
log.debug “Sending enroll response”
/* String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
//Resending the CIE in case the enroll request is sent before CIE is written
"zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}", “delay 200”,
“send 0x${device.deviceNetworkId} 1 ${endpointId}”, “delay 500”,
//Enroll Response
"raw 0x500 {01 23 00 00 00}",
“send 0x${device.deviceNetworkId} 1 1”, “delay 200”
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
private hex(value) {
new BigInteger(Math.round(value).toString()).toString(16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j–;
i++;
return array
Check out my code on the thread
What thread, this one? The code in post #43?
Man am looking forward to not seeing this little blue flashing light on my desk.
I put the code above in and am receiving temperature data and battery status, but nothing when I put the sensor in water. It beeps and blinks, but the ST app does not indicate that it’s got a wet notification. If there is anything I can do to test, let me know. I appreciate the work you are doing on this.
I suggest just using your tongue to bridge the circuit on the bottom of the sensor. It looks like I fried one of mine by getting water inside of the housing.
Once you get the new device code saved and updated you will need to configure the device, go to settings and save – this will subscribe to the b02 cluster report, and you should get the alarm on the ST app.
I’ll likely give this a try later. It’s been along day and I’ve been finishing up another special purpose smart app.
BTW - I use a little piece of metal to bridge the contacts. Hold it there for a few seconds and the alarm will sound. Coins don’t work. It has to be a decent conductor.
Let me see if I follow.
I went to My Device Handlers and clicked Create New Device Handler and then pasted the code above and saved it.
Then went to My Devices, selected the leaksmart sensor, clicked Edit, and selected leakSmart Moisture Sensor from the dropdown and clicked Update.
Am I missing anything?
Should I see something besides temp and battery on the device states?
Where you entered the new device type – there is a device simulator. Use this and choose your water sensor. Once installed via the simulator click configure… Then bridge the circuit on the base of the sensor to cause an alarm - you should see the icon for the device turn to wet from dry. Give that a try
Hot damn! Thank you for your help!
Excellent work! Now to find some more…
So, how were you able to determine the missing cluster? Is there some way to tell ST to listen to all messages from a device instead of specifying (which is what I assume the footprint is basically doing)?
From what I understand the footprint is in the raw data from the initial pairing of the device – it let’s the hub know it’s capabilities. From there I figured they used a custom/mfg specific cluster from the response I got from the person from leakSmart. So I tried the B02 cluster with attribute 0000 (state) to get a report and I was actually surprised I got a response when the alarm went off, since I got an unsupported attribute response trying to read the cluster/attrib in the refresh.
Sorry if I end up being a pest but I despise the instructions that ST has on this and being an app developer I want to know how to code these things. We’re you able to see the footprint when pairing? If so, where? I was unable to see these in the log and the tutorial was not helpful in telling me exactly where these could be found. Heck, I can’t even find a defined range within the cluster library that would contain it, but I admit I’m just skimming through and not really reading for context.
Once the device is paired go into “My Devices” click on the sensor. Look for the “Raw Description”. At least I think that is what you want.
Right in front of my face… Thanks.
It took me a while when I first started.
Any chance we can get this code up on GitHub in a repo so we can install it from there and get updates?
Here’s the latest complete code I have running, if @John_Luikart wants to integrate this into the repo that would be great.
metadata {
simulator {
preferences {
    section {
    section {
tiles(scale: 2) {
        backgroundColors:[
Map map = [:]
return result
Map resultMap = [:]
case 0x0001:
break
    case 0x0402:
        break
    case 0x0B02:
		break
else {
return resultMap
Map resultMap = [:]
else if (descMap.cluster == “0b02” && descMap.attrId == “0000”) {
log.debug “Parsing cluster B02 data”
//resultMap =
return resultMap
Map resultMap = [:]
return resultMap
return celsius
} else {
def result = [
value: '--',
translatable: true
else {
    if (volts > 4.5) {
        result.value = 100
    else {
            def minVolts = 15
            def maxVolts = 28
                volts = minVolts
                volts = maxVolts
            if (pct != null) {
                result.value = pct
        else {
            def minVolts = 2.1
            def maxVolts = 4.5
return result
log.debug 'TEMP’
if (tempOffset) {
value = v + offset
def descriptionText
else
return [
value: value,
translatable: true
log.debug "water"
def descriptionText
else
return [
value: value,
translatable: true
Map resultMap = [:]
switch(value) {
    	log.debug "dry"
        break
    	log.debug "wet"
        break
return resultMap
def refresh() {
def refreshCmds = [
return refreshCmds
def configure() {
def configCmds = [
int i = 0;
byte tmp;
while (j > i) {
tmp = array[j];
array[i] = tmp;
j–;
i++;
return array
sweet… waiting on my Leaksmarts to show up… :smiley:
GitHub integration would be nice
