LANnouncer Repository?
How do you add LANnouncer to SmartThings? I can’t find the repository on the IDE. All links to keybounce seem dead. I’m trying to add this function so I can use my mounted tablets to sound exit delay beeps.
Whenever you are using custom code, the quickest way to get an answer to questions is to put your post in the author thread for that particular custom code. The author will be automatically notified when there are new posts to their thread and other people who are using the same code will also see it and may be able to help. :sunglasses:
In this particular case:
However, I’m not sure that particular code is still being maintained.
I summarized the steps on how to install LANnouncer here but I believe the original author has moved on to Hubitat. The key bounce.com website seems unreachable at the moment but you can still get the apk directly from the google play store. You’ll also need the Device Handler for SmartThings, send me a PM and I’ll help you with that.
I sent you a PM. I am looking for the same information.
Thank you
Sent you a PM
Hi…i was reading your comments rgd installing Lannouncer on ST.
You mentioned a device code for it. I have been searching the web for two days trying to find it to no avail.
Would it be possible for you to provide it, or direct me to where i may locate a copy of it?
Thank you
Same question please. I am looking for the LANnouncer device handler code. The keybounce website is offline.
Thank you!
http://web.archive.org/web/20181026013735/http://www.keybounce.com/bin/LANdroid%20Alerter.groovy
I doubt it was updated after that version.
Awesome - thank you!
