Hi everyone,
i’m trying to create new device type for my LAN light switch. The problem is that SmartHub doesn’t actually send any request to switch REST server.
I’ve created a device based on this device type with device id: 0A000107:0D54 // 10.0.1.7:3412
and tried with it - no luck. I’ve tried to use virtual device in IDE - no luck.
when I open the uri in browser: http://10.0.1.7:3412/switch?name=corridorLight&state=on it turns on the light
when I open telnet to 10.0.1.7 3412 and write all lines from logs (in method doRequest) it turns on the light
but with this device type no luck
Could anyone help me with it? I don’t want to forward port and make this REST server available to everyone.
Here’s the code:
metadata {
definition (name: "Internal Switch", namespace: "narsul", author: "Anthony Peklo") {
capability "Switch"
capability "Refresh"
// simulator metadata
simulator {
// UI tile definitions
tiles {
standardTile("button", "device.switch", width: 2, height: 2, canChangeIcon: false) {
state "off", label: 'Off', action: "switch.on", icon: "st.Kids.kid10", backgroundColor: "#ffffff", nextState: "on"
state "on", label: 'On', action: "switch.off", icon: "st.Kids.kid10", backgroundColor: "#79b821", nextState: "off"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "button"
details(["button", "refresh"])
log.debug "Parsing '${description}'"
def on() {
log.debug('on')
doRequest('on')
sendEvent(name: "switch", value: "on")
def off() {
log.debug('off')
doRequest('off')
sendEvent(name: "switch", value: "off")
def doRequest(action) {
// device.deviceNetworkId = "0A000107:0D54"
try {
def hubAction = new physicalgraph.device.HubAction(
method: 'GET',
path: "/switch?name=corridorLight&state=${action}",
headers: [HOST:getHostAddress()]
log.debug hubAction
hubAction
catch (Exception e) {
log.debug "Hit Exception $e on $hubAction"
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private getHostAddress() {
def parts = device.deviceNetworkId.split(":")
def ip = convertHexToIP(parts[0])
def port = convertHexToInt(parts[1])
return ip + ":" + port
P.S. By the way method ‘parse’ is not bing called too
