mattmartz
(Matt Martz)
October 9, 2014, 1:10pm
1
I can’t seem to figure out how to POST a JSON object using hubaction. I can’t attach anything to the “body”.
Using these docs: http://docs.smartthings.com/en/latest/cloud-and-lan-connected-device-types-developers-guide/building-lan-connected-device-types/building-the-device-type.html
Clearly there’s some kind of method for UPnP/SOAP since they have “action” and “body”… but when I try to do the same using a REST call nothing gets attached.
I have managed to hack something by adding my json object into the header, but that is less than ideal. Is there a way to do a rest call with https so that it is encrypted?
My code where I do this is around lines 228 of this: https://github.com/oehokie/SmartDSC/blob/master/devicetypes/DSCAlarmThing.groovy
@Ben @urman ?
obycode
(Brice; SmartRulesApp.com)
October 9, 2014, 3:57pm
2
Check out my code for ObyThing Music - https://github.com/obycode/obything/blob/master/ObyThingMusic.groovy
Take a look at this function:
private sendCommand(command) {
def path = "/post.html"
def headers = [:]
headers.put("HOST", getHostAddress())
headers.put("Content-Type", "application/x-www-form-urlencoded")
def method = "POST"
def result = new physicalgraph.device.HubAction(
method: method,
path: path,
body: command,
headers: headers
result
Its just called with a string, so if you have a json object, convert it to a string - object.toString()
mattmartz
(Matt Martz)
October 9, 2014, 4:38pm
3
Hmmm… I am almost positive I tried that before and it didn’t work… But I don’t think I had some of that header line. I will try it when I get home.
I definitely converted it to a string too.
mattmartz
(Matt Martz)
October 9, 2014, 10:23pm
4
@obycode :
Just got home and tried it. I think it was a combination of things. I ended up using:
def json = new JsonBuilder()
json.call("command":"${command}","password":"${settings.hostpassword}")
def headers = [:]
headers.put("HOST", "$host:$port")
headers.put("Content-Type", "application/json")
log.debug "The Header is $headers"
def method = "POST"
try {
def hubAction = new physicalgraph.device.HubAction(
method: method,
path: path,
body: json,
headers: headers,
log.debug hubAction
hubAction
catch (Exception e) {
log.debug "Hit Exception $e on $hubAction"
And between that and an error I had on my server side (bodyParser was deprecated in Express 4 and I didn’t “use” it to begin with… oops…) that fixed it. Thanks!
