LAN API Integration
Hi,
Currently we are communicating to our Devices through Cloud API. Can we communicate directly with our Devices? There are some possibility that Internet may go down, so LAN will be more reliable.
Thanks in advance.
@gpdipalmerahtimur, SmartThings is currently moving more functionality to run locally on your LAN. That said, it is not possible in the SmartThings world to have a fully-functioning system when your Internet connection is down, nor do I believe Samsung has promised to make this a possibility someday.
If this is truly important to you, I would suggest that you investigate Hubitat Elevation.
