Keen + Ecobee + ecobeeSetZonesWithSchedule
I just bought ecobeeSetZonesWithSchedule to manage my keen smartvents but i’m having troubles configuring it. I was able to install the smart app, add my rooms. zones, and vents, but when i get to the end “An unexpected error has occurred”.
The only thing that i can think is causing the problem is the fact that when i go to select “which ecobee climate/program” the only option is “null”.
Any advise? Thanks!
Hi @ignacio82,
As indicated at the ST community wiki and in my thread, the ecobeeSetZoneWithSchedule was designed to work only with myEcobee device (available at my store). Refer to the prerequisites section:
_http://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule_
The smartapp cannot work with the ST stock device or any other DTHs as MyEcobee device is the only ecobee device that knows the complete list of active ecobee climates/programs running at your home and which one runs at a given time.
So, if you want to use the smartapp, please purchase MyEcobee device at my store.
Also, if you have any questions about my DTHs or smartapps, please send your questions to services@maisonsecomatiq.com as it’s easier for me to respond to your requests through gmail conversations. I’m able then to get the user context and history of each conversation.
Regards.
