I am trying to use a device handler for Veskys IP camera. I modified another handler to fit this camera and it works.
But this camera has a weird image dimension/resolution. Wİth the default view of the device handler , image gets stretched horizontally and it does not appear good.
Is there a way to change the dimensions on the device view ?
RBoy
3
No image rendering is determined by the ST Mobile app. You can try to play with the Image Carousel size in the device handler and see if that helps. You can try a different device (iOS or Android) as they tend to have subtle differences in rendering.
