@jpansarasa Would you mind adding an option to add the cycle time to the notification message? That would be great. In the past I had trouble configured an aeon outlet to report the power consistently and seeing the cycle times might help me to know when the outlet is reporting correctly and when it is not reporting correctly.
Okay, we got 2 laundry notifications for one event from this app. They were a second apart. The stock app only sent one notification.
The notification from the stock app is between the 2 notifications from this app as shown in the image.
I do not think that I ever saw this in the past. BUT, since I did not have duration before, I am not sure that this did not happen and I just did not notice it.
Is this a bug in the smart app, or a bug in the smartthings hub?
Yup. This happens. It is a confluence of problems.
The powerHandler(...) method in the app is called for every power event. The device handler sends events when the power changes by a minimum wattage (50 watts is the default) and also when the wattage changes by some percentage (10% is the default). Sometimes these two events are triggered close enough together that the state is not persisted between the calls. (For the curious, SmartThings Documentation - Using State ) I have erred on the side of getting two notifications is better than not getting notifications.
I have modified the code to use atomicState, hopefully this will solve the problem. I remember trying this early on and it did not work but let’s try it again!
Hey James, great app man. The wife loves it, and gives me one more reason to justify the SmartThings addiction. One request/question though, have you considered adding switch or bulb control based on laundry status? Maybe turning on a bulb (like the osram rgbw) at a certain color? Or simply turning on a bulb/switch?
No, I was seeing something else. I deleted it because I found Brandon Miller’s updated Laundry Monitor and it works as I desire. Perhaps there was yet another “better Laundry Monitor” out there, not yours, and that’s what I had loaded? There do seem to be lots of attempts to do laundry monitors.
So I now have the Miller monitor on my washer (using the power reading from the Iris smart plug) and it works well, and I have the official ST laundry monitor (using the multi vibration sensor) reporting on the dryer. And that works well too. And I have my android tablets intercepting the notifications and saying them out loud, and the Notifications for Android TV popping them on my Bravia. I do look forward to the day Echo can receive push notifications… thanks James for trying to help on this. I do appreciate that you stepped up, even though it turned out to not be your app.
