I'm not able to use Mariano's Edge Beta Drivers for POPP Zigbee Thermostat
I have a POPP Zigbee Thermostat 701721.
I’m trying to use Mariano’s Edge Beta Driver from channel: https://callaway.smartthings.com/channels/c8bb99e1-04a3-426b-9d94-2d260134d624
I can see the driver installed on my hub:
But I’m not able to select this driver in my device:
In the init.lua I can see that my device is there
https://github.com/Mariano-Github/Edge-Drivers-Beta/blob/main/zigbee-thermostat-stock-mc/src/popp_danfoss/init.lua
The Manufacturer Code and Model seem to be the same:
What am I doing wrong?
Lech
The screenshot of the AWA shows your model as eT093WRG not eT093WRO.
Yeah - that is probably the issue. I did some research and it seems the “O” version is an older version and “G” is the newer version, but from development standpoint they are the same.
I guess I’ll try to contact the author of the drivers and ask him to update it—it should be simple.
Heard reports from other users who aren’t able to select drivers even though there a fingerprint match. Would be curious to know if it gets resolved for you.
I have seen that the stock driver was modified and does not use the thermostatOperatingState capability either.
The old driver did use it and it worked with the defaults.
If you want, I add it to the zigbee Thermostat Mc driver with the thermostatOperatingState capability and try it.
Have you used the stock zigbee Thermostat driver?
Please add it. Will you test it or should I do it?
I tried these drivers:
Please bear with me - I’m very new to SmartThings (but I’m a quick learner) - I’m not sure if any of the above are stock drivers.
The Zigbee Thermostat without a named Driver Channel is a stock driver. Production stock drivers don’t indicate a Driver Channel while Beta stock drivers are denoted as " SmartThings Drivers (Beta)". Community developed drivers show the developer’s channel name.
Considering that you have used both the Popp driver and the stock smartthings, which removed the thermostatOperatingState capability, it is very possible that the device does not support that attribute.
I have done this TEST driver, which has the thermostatOperatingState capability just like the old smartthings stock driver had.
Install this TEST driver on your hub and make a driver change from the website or app
Try to see if it works and if it works I will update it to the newer driver version of smartthings, which has more features and settings
 Name         Zigbee Thermostat Mc-TEST
 Version      2024-04-04T20:24:40.121009706
- id: "D5X84YU/eT093WRG"
    deviceLabel: POPP Thermostat
    manufacturer: D5X84YU
    model: eT093WRG
    deviceProfileName: thermostat-popp-danfoss
I guess it doesn’t work…
I’m just wondering why so many more attributes are available in the Home Assistant related zigbee integrations (zigbee2mqtt, deconz and ZHA), that are not available for SmartThings. (see here)
Is it some kind of limitation of ST? Is there a workaround?
Are try if operating status appears performing a refresh command by swiping down in the app or pressing refresh command button in web advanced users?
If what it says in the Zigbee2MQTT link is true, the running_state attribute should be functional; it is what the smartthings driver uses to emit the operating status of the thermostat. If it doesn’t work, it is because it is not supported or is incorrectly configured.
Smarttings also supports the pi_heating_demand attribute, which sends the % opening of the valve, I don’t understand why Popp doesn’t implement it in its driver.
If you want tomorrow, I will try to configure the running_state attribute and try to see if it works
smartthings supports most standard attributes of the thermostat cluster, but some manufacturer uses custom attributes for some functions:
function Thermostat.attr_id_map()
    return {
    [0x0000] = "LocalTemperature",
    [0x0001] = "OutdoorTemperature",
    [0x0002] = "Occupancy",
    [0x0003] = "AbsMinHeatSetpointLimit",
    [0x0004] = "AbsMaxHeatSetpointLimit",
    [0x0005] = "AbsMinCoolSetpointLimit",
    [0x0006] = "AbsMaxCoolSetpointLimit",
    [0x0007] = "PICoolingDemand",
    [0x0008] = "PIHeatingDemand",
    [0x0009] = "HVACSystemTypeConfiguration",
    [0x0010] = "LocalTemperatureCalibration",
    [0x0011] = "OccupiedCoolingSetpoint",
    [0x0012] = "OccupiedHeatingSetpoint",
    [0x0013] = "UnoccupiedCoolingSetpoint",
    [0x0014] = "UnoccupiedHeatingSetpoint",
    [0x0015] = "MinHeatSetpointLimit",
    [0x0016] = "MaxHeatSetpointLimit",
    [0x0017] = "MinCoolSetpointLimit",
    [0x0018] = "MaxCoolSetpointLimit",
    [0x0019] = "MinSetpointDeadBand",
    [0x001A] = "RemoteSensing",
    [0x001B] = "ControlSequenceOfOperation",
    [0x001C] = "SystemMode",
    [0x001D] = "AlarmMask",
    [0x001E] = "ThermostatRunningMode",
    [0x0020] = "StartOfWeek",
    [0x0021] = "NumberOfWeeklyTransitions",
    [0x0022] = "NumberOfDailyTransitions",
    [0x0023] = "TemperatureSetpointHold",
    [0x0024] = "TemperatureSetpointHoldDuration",
    [0x0025] = "ThermostatProgrammingOperationMode",
    [0x0029] = "ThermostatRunningState",
    [0x0030] = "SetpointChangeSource",
    [0x0031] = "SetpointChangeAmount",
    [0x0032] = "SetpointChangeSourceTimestamp",
    [0x0034] = "OccupiedSetback",
    [0x0035] = "OccupiedSetbackMin",
    [0x0036] = "OccupiedSetbackMax",
    [0x0037] = "UnoccupiedSetback",
    [0x0038] = "UnoccupiedSetbackMin",
    [0x0039] = "UnoccupiedSetbackMax",
    [0x003A] = "EmergencyHeatDelta",
    [0x0040] = "ACType",
    [0x0041] = "ACCapacity",
    [0x0042] = "ACRefrigerantType",
    [0x0043] = "ACCompressorType",
    [0x0044] = "ACErrorCode",
    [0x0045] = "ACLouverPosition",
    [0x0046] = "ACCoilTemperature",
    [0x0047] = "ACCapacityFormat",
end
This version of the driver configures reports of the running_state attribute.
For the attribute to be configured you would have to uninstall or reinstall one thermostat, for the doConfigure lifecycle to run.
 Version      2024-04-04T22:17:22.46288096
Nothing has changed after refresh.
I installed the new driver, then removed the thermostat from the app, then factory reset the thermostat and then I re-added it in the app.
I double checked that the latest test driver is in use.
I can see there attributes:
It would be necessary to check it with the CLI logs, to see what the device responds, but it seems that it does not support the attribute or responds with a value not recognized by the driver.
If you want to publish the pairing logs with the CLI I could analyze them, maybe device answer the PIHeatingDemand attribute
Is this what you’re looking for?
Edit:
I noticed something. In the log I pasted, there is a line:
2024-04-05T11:50:20.040561308Z INFO Zigbee Thermostat Mc-TEST <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCA, rssi: -77, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x22, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, PIHeatingDemand: 0x04 > > > >
Later the following line appeared (it’s not included in the logs I shared):
2024-04-05T11:55:22.615852362Z INFO Zigbee Thermostat Mc-TEST <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -83, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, PIHeatingDemand: 0x07 > > > >
Later I changed the heating setpoint from 21 to 12 and the following line appeared in the logs:
024-04-05T12:00:24.670982207Z INFO Zigbee Thermostat Mc-TEST <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCE, rssi: -76, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x34, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, PIHeatingDemand: 0x00 > > > >
Then I change the heating setpoint to 35 and the following line appeared:
2024-04-05T12:12:20.249392846Z INFO Zigbee Thermostat Mc-TEST <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -83, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x43, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, PIHeatingDemand: 0x04 > > > >
Looks like the PiHeatingDemand changes when there is demand for heating.
@Lech_Jonczyk
then I look at it, now I’m out.
Does not support OperatingState, does support PIHeatingDemand
BTW - I noticed, that using your drivers, I can change in the app the heating setpoint with an interval of 1, whereas in the POPP drivers I can change it with 0.5 interval. Is it possible to update your drivers to handle the 0.5 degree interval?
Yes, is possible.
Could you set Heat set point to see valve open value in cli logs?
In sinope thermostar heatingDemand.value < 10 is valve closed, operating state = idle
In popp thermostat it could see differet
I set the heat setpoint to 34.5 (measured temperature is 20)
2024-04-05T19:34:21.809980571Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:34:26.888561071Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:34:26.950187280Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD0, rssi: -74, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0012, DataType: Int16, OccupiedHeatingSetpoint: 3450 >, < AttributeRecord || AttributeId: 0x0030, DataType: Enum8, SetpointChangeSource: SetpointChangeSource[MANUAL] > > > >
2024-04-05T19:34:26.966240446Z TRACE Virtual Devices V2  Received event with handler capability
2024-04-05T19:34:26.975876696Z TRACE Zigbee Thermostat Mc-TEST  Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2024-04-05T19:34:26.989152280Z INFO Zigbee Thermostat Mc-TEST  Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: OccupiedHeatingSetpoint
2024-04-05T19:34:26.996539863Z INFO Virtual Devices V2  <Device: dc8233fa-9aad-4f8b-aca6-71afaba81767 (Zielony Reczne Grzanie)> received command: {"args":{},"capability":"switch","command":"on","component":"main","positional_args":{}}
2024-04-05T19:34:27.011205321Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> emitting event: {"attribute_id":"heatingSetpoint","capability_id":"thermostatHeatingSetpoint","component_id":"main","state":{"unit":"C","value":34.5}}
2024-04-05T19:34:27.017299030Z TRACE Virtual Devices V2  Found CapabilityCommandDispatcher handler in vedgeDriver
2024-04-05T19:34:27.022214696Z INFO Virtual Devices V2  Virtual switch turned >> on <<
2024-04-05T19:34:27.030813446Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:34:27.035806071Z INFO Virtual Devices V2  <Device: dc8233fa-9aad-4f8b-aca6-71afaba81767 (Zielony Reczne Grzanie)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-04-05T19:34:27.043740905Z DEBUG Virtual Devices V2  Grzanie Zielony Reczne device thread event handled
2024-04-05T19:34:51.817440241Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:35:21.826855814Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:35:35.489916682Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:35:35.572201095Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCA, rssi: -79, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, LocalTemperature: 1974 > > > >
2024-04-05T19:35:35.583467100Z TRACE Zigbee Thermostat Mc-TEST  Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2024-04-05T19:35:35.592370133Z INFO Zigbee Thermostat Mc-TEST  Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: LocalTemperature
2024-04-05T19:35:35.609821187Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":19.74}}
2024-04-05T19:35:35.629824851Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:35:51.840211377Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:36:20.079838755Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:36:20.339827047Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, LocalTemperature: 2000 > > > >
2024-04-05T19:36:20.374774922Z TRACE Zigbee Thermostat Mc-TEST  Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2024-04-05T19:36:20.387593130Z INFO Zigbee Thermostat Mc-TEST  Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: LocalTemperature
2024-04-05T19:36:20.424444505Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":20.0}}
2024-04-05T19:36:20.507786589Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:36:21.840908464Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:36:51.847183134Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:37:20.013033054Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:37:20.070151971Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCE, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, LocalTemperature: 2010 > > > >
2024-04-05T19:37:20.077189888Z TRACE Zigbee Thermostat Mc-TEST  Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2024-04-05T19:37:20.111002929Z INFO Zigbee Thermostat Mc-TEST  Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: LocalTemperature
2024-04-05T19:37:20.221798221Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":20.1}}
2024-04-05T19:37:20.279830929Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:37:21.856289263Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:37:51.858045391Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:38:21.859424312Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:38:51.867018107Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:38:56.869769357Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:38:56.908105982Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -72, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0008, DataType: Uint8, PIHeatingDemand: 0x64 > > > >
2024-04-05T19:38:56.919773316Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:39:21.876449780Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:39:29.189842650Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:39:29.218023024Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCE, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0012, DataType: Int16, OccupiedHeatingSetpoint: 3450 > > > >
2024-04-05T19:39:29.224302788Z TRACE Zigbee Thermostat Mc-TEST  Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2024-04-05T19:39:29.228825381Z INFO Zigbee Thermostat Mc-TEST  Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: OccupiedHeatingSetpoint
2024-04-05T19:39:29.233777273Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> emitting event: {"attribute_id":"heatingSetpoint","capability_id":"thermostatHeatingSetpoint","component_id":"main","state":{"unit":"C","value":34.5}}
2024-04-05T19:39:29.239345972Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:39:51.878189573Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:40:21.886780707Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:40:51.888547510Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:41:21.889256555Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:41:51.896708267Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:42:20.049791312Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:42:20.090347895Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCE, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x60, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, LocalTemperature: 1999 > > > >
2024-04-05T19:42:20.096945437Z TRACE Zigbee Thermostat Mc-TEST  Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2024-04-05T19:42:20.101476395Z INFO Zigbee Thermostat Mc-TEST  Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: LocalTemperature
2024-04-05T19:42:20.106674479Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> emitting event: {"attribute_id":"temperature","capability_id":"temperatureMeasurement","component_id":"main","state":{"unit":"C","value":19.99}}
2024-04-05T19:42:20.112127145Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:42:20.399757895Z TRACE Zigbee Thermostat Mc-TEST  Received event with handler zigbee
2024-04-05T19:42:20.407571020Z INFO Zigbee Thermostat Mc-TEST  <ZigbeeDevice: 84e0554b-36f9-43a1-b820-13d44c9a1d33 [0xD52B] (POPP Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD52B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -73, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0C, mfg_code: 0x1246, seqno: 0x61, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x404A, DataType: Int16, Int16: 1 > > > >
2024-04-05T19:42:20.412870145Z DEBUG Zigbee Thermostat Mc-TEST  POPP Thermostat device thread event handled
2024-04-05T19:42:21.899648729Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:42:51.906013691Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
2024-04-05T19:43:21.919110631Z DEBUG Zigbee Thermostat Mc-TEST  driver device thread event handled
It seems that the valve indicates 100% open (0x64)
So I’m going to set it so that when I send values < 10% it shows operatingState: Idle, just like Sinope?
This TEST version is identical to the last stock version, with open window settings…and others, adding the ThermostatOperatingState capability and the code to handle it.
For it to work you have to reinstall the thermostat with this version of the driver or since it is already configured you can change to another thermostat driver and then return to this TEST version.
If it works well I will merge it with the Mc version
 Version      2024-04-05T19:57:17.146634191
Just one more update before I test the new drivers. I extracted the chronological record of setting heat point, measured temperature and PIHeatingDemand. Not sure it helps, but I’m posting just in case:
time action value
2024-04-05T11:40:44.335295860Z SetHeatingPoint 21
2024-04-05T11:40:44.473483148Z TemperatureMeasurement 19.74
2024-04-05T11:40:44.800164809Z TemperatureMeasurement 19.74
2024-04-05T11:41:42.923009689Z TemperatureMeasurement 19.74
2024-04-05T11:42:43.385095002Z TemperatureMeasurement 19.84
2024-04-05T11:43:43.844760718Z TemperatureMeasurement 19.85
2024-04-05T11:44:44.305109005Z TemperatureMeasurement 19.83
2024-04-05T11:45:44.764665345Z TemperatureMeasurement 19.85
2024-04-05T11:46:45.215970936Z TemperatureMeasurement 19.82
2024-04-05T11:47:46.029875526Z TemperatureMeasurement 19.81
2024-04-05T11:48:21.447931918Z SetHeatingPoint 21
2024-04-05T11:48:46.481230755Z TemperatureMeasurement 19.76
2024-04-05T11:49:46.699481262Z TemperatureMeasurement 19.76
2024-04-05T11:50:20.040561308Z PIHeatingDemand 0x04
2024-04-05T11:50:47.077877769Z TemperatureMeasurement 19.8
2024-04-05T11:51:47.531225776Z TemperatureMeasurement 19.8
2024-04-05T11:52:48.026099187Z TemperatureMeasurement 19.83
2024-04-05T11:53:48.490090018Z TemperatureMeasurement 19.8
2024-04-05T11:54:48.966275983Z TemperatureMeasurement 19.8
2024-04-05T11:55:22.615852362Z PIHeatingDemand 0x07
2024-04-05T11:55:49.421135157Z TemperatureMeasurement 19.82
2024-04-05T11:56:49.850888626Z TemperatureMeasurement 19.81
2024-04-05T11:57:50.311359716Z TemperatureMeasurement 19.81
2024-04-05T11:58:25.785251679Z SetHeatingPoint 21
2024-04-05T11:58:26.854334637Z SetHeatingPoint 12
2024-04-05T11:58:27.327959179Z SetHeatingPoint 12
2024-04-05T11:58:50.770795140Z TemperatureMeasurement 19.79
2024-04-05T11:59:51.247082689Z TemperatureMeasurement 19.78
2024-04-05T12:00:24.670982207Z PIHeatingDemand 0x00
2024-04-05T12:00:33.955064249Z SetHeatingPoint 12
2024-04-05T12:00:34.180066249Z TemperatureMeasurement 19.77
2024-04-05T12:00:51.714977252Z TemperatureMeasurement 19.77
2024-04-05T12:01:52.170665300Z TemperatureMeasurement 19.78
2024-04-05T12:02:52.632516058Z TemperatureMeasurement 19.8
2024-04-05T12:03:53.091550356Z TemperatureMeasurement 19.78
2024-04-05T12:04:53.934577074Z TemperatureMeasurement 19.78
2024-04-05T12:05:54.386115790Z TemperatureMeasurement 19.78
2024-04-05T12:06:54.574890505Z TemperatureMeasurement 19.77
2024-04-05T12:07:54.950539637Z TemperatureMeasurement 19.79
2024-04-05T12:08:31.425144571Z SetHeatingPoint 12
2024-04-05T12:08:55.631937824Z TemperatureMeasurement 19.78
2024-04-05T12:09:55.863075581Z TemperatureMeasurement 19.78
2024-04-05T12:10:40.880026003Z SetHeatingPoint 35
2024-04-05T12:10:40.998752170Z SetHeatingPoint 35
2024-04-05T12:10:56.386051255Z TemperatureMeasurement 19.79
2024-04-05T12:11:56.958601387Z TemperatureMeasurement 19.98
2024-04-05T12:12:20.249392846Z PIHeatingDemand 0x04
2024-04-05T12:12:57.306526699Z TemperatureMeasurement 20.12
2024-04-05T12:13:57.750989461Z TemperatureMeasurement 20
2024-04-05T12:14:58.197022176Z TemperatureMeasurement 19.92
2024-04-05T12:15:58.670676600Z TemperatureMeasurement 19.92
2024-04-05T12:16:59.130165641Z TemperatureMeasurement 19.87
2024-04-05T12:17:22.372781227Z PIHeatingDemand 0x0C
2024-04-05T12:17:59.634940899Z TemperatureMeasurement 19.86
2024-04-05T12:19:00.060986906Z TemperatureMeasurement 19.86
2024-04-05T12:20:00.512454205Z TemperatureMeasurement 19.85
2024-04-05T12:20:45.429938197Z SetHeatingPoint 35
2024-04-05T12:21:01.323596282Z TemperatureMeasurement 19.85
2024-04-05T12:22:01.758750622Z TemperatureMeasurement 19.85
2024-04-05T12:22:24.663670250Z PIHeatingDemand 0x0E
2024-04-05T12:23:01.939304671Z TemperatureMeasurement 19.86
2024-04-05T12:24:02.331165525Z TemperatureMeasurement 19.91
2024-04-05T12:25:02.863940453Z TemperatureMeasurement 19.92
2024-04-05T12:26:03.262807919Z TemperatureMeasurement 19.93
2024-04-05T12:27:03.724632426Z TemperatureMeasurement 19.96
2024-04-05T12:27:27.290479054Z PIHeatingDemand 0x11
2024-04-05T12:28:04.186490652Z TemperatureMeasurement 19.95
2024-04-05T12:29:04.675288235Z TemperatureMeasurement 19.92
2024-04-05T12:30:05.183276095Z TemperatureMeasurement 19.91
2024-04-05T12:30:50.041439100Z SetHeatingPoint 35
2024-04-05T12:31:05.718505602Z TemperatureMeasurement 19.92
2024-04-05T12:32:06.064460523Z TemperatureMeasurement 19.94
2024-04-05T12:32:29.304621924Z PIHeatingDemand 0x13
2024-04-05T12:33:06.515344010Z TemperatureMeasurement 19.96
2024-04-05T12:34:06.961692238Z TemperatureMeasurement 19.99
2024-04-05T12:35:07.413610787Z TemperatureMeasurement 20.02
2024-04-05T12:36:07.886505843Z TemperatureMeasurement 20.05
2024-04-05T12:37:08.410851630Z TemperatureMeasurement 20.06
2024-04-05T12:37:31.583654633Z PIHeatingDemand 0x16
2024-04-05T12:38:09.247845596Z TemperatureMeasurement 20.06
2024-04-05T12:39:09.465727603Z TemperatureMeasurement 20.08
2024-04-05T12:40:09.810012933Z TemperatureMeasurement 20.06
2024-04-05T12:40:54.890460550Z SetHeatingPoint 35
2024-04-05T12:41:10.200997927Z TemperatureMeasurement 20.06
2024-04-05T12:42:10.661239184Z TemperatureMeasurement 20.08
2024-04-05T12:42:33.871494687Z PIHeatingDemand 0x18
2024-04-05T12:43:11.114046317Z TemperatureMeasurement 20.09
2024-04-05T12:44:11.572843997Z TemperatureMeasurement 20.09
2024-04-05T12:45:12.061421803Z TemperatureMeasurement 20.09
2024-04-05T12:46:12.621704819Z TemperatureMeasurement 20.09
2024-04-05T12:47:13.030973043Z TemperatureMeasurement 20.1
2024-04-05T12:47:36.243904004Z PIHeatingDemand 0x1B
2024-04-05T12:48:13.488461510Z TemperatureMeasurement 20.1
2024-04-05T12:49:13.981055532Z TemperatureMeasurement 20.09
2024-04-05T12:50:14.471700413Z TemperatureMeasurement 20.07
2024-04-05T12:50:59.370981390Z SetHeatingPoint 35
2024-04-05T12:51:14.981891142Z TemperatureMeasurement 20.07
2024-04-05T12:52:15.402122489Z TemperatureMeasurement 20.07
2024-04-05T12:52:38.592444572Z PIHeatingDemand 0x1D
2024-04-05T12:53:15.839874545Z TemperatureMeasurement 20.08
2024-04-05T12:54:16.670127294Z TemperatureMeasurement 20.07
2024-04-05T12:55:17.090325487Z TemperatureMeasurement 20.07
2024-04-05T12:56:17.363952061Z TemperatureMeasurement 20.07
2024-04-05T12:57:17.725093848Z TemperatureMeasurement 20.07
2024-04-05T12:57:40.911311583Z PIHeatingDemand 0x20
2024-04-05T12:58:18.155192578Z TemperatureMeasurement 20.07
2024-04-05T12:59:18.580689835Z TemperatureMeasurement 20.06
2024-04-05T13:00:19.042176266Z TemperatureMeasurement 20.06
2024-04-05T13:01:03.923118903Z SetHeatingPoint 35
2024-04-05T13:01:19.779957904Z TemperatureMeasurement 20.06
2024-04-05T13:02:20.021053948Z TemperatureMeasurement 20.07
2024-04-05T13:02:43.385701603Z PIHeatingDemand 0x22
2024-04-05T13:03:20.519367286Z TemperatureMeasurement 20.05
2024-04-05T13:04:21.040820590Z TemperatureMeasurement 20.06
2024-04-05T13:05:21.492893565Z TemperatureMeasurement 20.06
2024-04-05T13:06:21.932249985Z TemperatureMeasurement 20.05
2024-04-05T13:07:22.297795370Z TemperatureMeasurement 20.03
2024-04-05T13:07:45.471107213Z PIHeatingDemand 0x25
2024-04-05T13:08:22.737888755Z TemperatureMeasurement 20.05
2024-04-05T13:09:23.152388318Z TemperatureMeasurement 20.05
2024-04-05T13:10:23.587431687Z TemperatureMeasurement 20.03
2024-04-05T13:11:08.425441639Z SetHeatingPoint 35
2024-04-05T13:11:24.399862016Z TemperatureMeasurement 20.02
2024-04-05T13:12:24.885188648Z TemperatureMeasurement 20.02
2024-04-05T13:12:47.811151315Z PIHeatingDemand 0x27
2024-04-05T13:13:25.161311153Z TemperatureMeasurement 20.02
2024-04-05T13:14:25.473038243Z TemperatureMeasurement 20.01
2024-04-05T13:15:25.862705417Z TemperatureMeasurement 20.02
2024-04-05T13:16:26.321154494Z TemperatureMeasurement 20.02
2024-04-05T13:17:26.852817191Z TemperatureMeasurement 20.02
2024-04-05T13:17:50.038358278Z PIHeatingDemand 0x2A
2024-04-05T13:18:27.314878907Z TemperatureMeasurement 20.04
2024-04-05T13:19:27.735521164Z TemperatureMeasurement 20.05
2024-04-05T13:20:28.227641025Z TemperatureMeasurement 20.04
2024-04-05T13:21:13.022120027Z SetHeatingPoint 35
2024-04-05T13:21:28.689923987Z TemperatureMeasurement 20.02
2024-04-05T13:22:29.109563827Z TemperatureMeasurement 20.05
2024-04-05T13:22:52.302532872Z PIHeatingDemand 0x2C
2024-04-05T13:23:29.584945001Z TemperatureMeasurement 20.09
2024-04-05T13:24:30.023679231Z TemperatureMeasurement 20.05
2024-04-05T13:25:30.493384425Z TemperatureMeasurement 20.05
2024-04-05T13:26:30.955220224Z TemperatureMeasurement 20.04
2024-04-05T13:27:31.561377940Z TemperatureMeasurement 20.03
2024-04-05T13:27:54.593144276Z PIHeatingDemand 0x2F
2024-04-05T13:28:32.401715491Z TemperatureMeasurement 20.06
2024-04-05T13:29:32.551063122Z TemperatureMeasurement 20.06
2024-04-05T13:30:32.846769671Z TemperatureMeasurement 20.08
2024-04-05T13:31:17.892494134Z SetHeatingPoint 35
2024-04-05T13:31:35.319868761Z TemperatureMeasurement 20.09
2024-04-05T13:32:33.771825793Z TemperatureMeasurement 20.08
2024-04-05T13:32:56.891872751Z PIHeatingDemand 0x31
2024-04-05T13:33:34.250237836Z TemperatureMeasurement 20.09
2024-04-05T13:34:34.702044802Z TemperatureMeasurement 20.09
2024-04-05T13:35:35.124990601Z TemperatureMeasurement 20.08
2024-04-05T13:36:35.672435553Z TemperatureMeasurement 20.08
2024-04-05T13:37:36.021828358Z TemperatureMeasurement 20.08
2024-04-05T13:37:59.193232819Z PIHeatingDemand 0x34
2024-04-05T13:38:36.489018865Z TemperatureMeasurement 20.06
2024-04-05T13:39:37.011219581Z TemperatureMeasurement 20.07
2024-04-05T13:40:37.403098918Z TemperatureMeasurement 20.07
2024-04-05T13:41:22.212595555Z SetHeatingPoint 35
2024-04-05T13:41:37.875380807Z TemperatureMeasurement 20.07
2024-04-05T13:42:38.492215981Z TemperatureMeasurement 20.07
2024-04-05T13:43:01.561593608Z PIHeatingDemand 0x36
2024-04-05T13:43:38.895199529Z TemperatureMeasurement 20.05
2024-04-05T13:44:39.248488490Z TemperatureMeasurement 20.08
2024-04-05T13:45:40.096240682Z TemperatureMeasurement 20.08
2024-04-05T13:46:40.321772231Z TemperatureMeasurement 20.07
2024-04-05T13:47:40.629948321Z TemperatureMeasurement 20.07
2024-04-05T13:48:03.761708158Z PIHeatingDemand 0x39
2024-04-05T13:48:41.091437553Z TemperatureMeasurement 20.09
2024-04-05T13:49:41.564115497Z TemperatureMeasurement 20.08
2024-04-05T13:50:42.022788796Z TemperatureMeasurement 20.08
2024-04-05T13:51:26.822117009Z SetHeatingPoint 35
2024-04-05T13:51:42.480980636Z TemperatureMeasurement 20.09
2024-04-05T13:52:42.933327112Z TemperatureMeasurement 20.1
2024-04-05T13:53:06.281222363Z PIHeatingDemand 0x3B
2024-04-05T13:53:43.429865701Z TemperatureMeasurement 20.12
2024-04-05T13:54:43.852113999Z TemperatureMeasurement 20.14
2024-04-05T13:55:44.339857382Z TemperatureMeasurement 20.28
2024-04-05T13:56:44.766657829Z TemperatureMeasurement 20.56
2024-04-05T13:57:45.221408862Z TemperatureMeasurement 20.61
2024-04-05T13:58:08.384609323Z PIHeatingDemand 0x3D
2024-04-05T13:58:45.695483577Z TemperatureMeasurement 20.56
2024-04-05T13:59:43.498383293Z SetHeatingPoint 21
2024-04-05T13:59:43.552215418Z SetHeatingPoint 21
2024-04-05T13:59:44.281079876Z SetHeatingPoint 20
2024-04-05T13:59:44.827846710Z SetHeatingPoint 20
2024-04-05T13:59:46.169867418Z TemperatureMeasurement 20.49
2024-04-05T14:00:46.606006046Z TemperatureMeasurement 20.43
2024-04-05T14:01:47.485116313Z TemperatureMeasurement 20.4
2024-04-05T14:02:47.786587098Z TemperatureMeasurement 20.34
2024-04-05T14:03:10.670757059Z PIHeatingDemand 0x40
2024-04-05T14:03:48.242381356Z TemperatureMeasurement 20.33
2024-04-05T14:03:56.526775648Z SetHeatingPoint 20
2024-04-05T14:03:56.581996273Z TemperatureMeasurement 20.33
2024-04-05T14:03:59.859872982Z SetHeatingPoint 20
2024-04-05T14:04:00.030394940Z TemperatureMeasurement 20.33
2024-04-05T14:04:01.863299024Z SetHeatingPoint 20
2024-04-05T14:04:46.503890737Z SetHeatingPoint 20
2024-04-05T14:05:01.814721994Z SetHeatingPoint 20
2024-04-05T14:05:24.823399503Z SetHeatingPoint 20
2024-04-05T14:05:24.871237284Z TemperatureMeasurement 20.24
2024-04-05T14:06:11.185761712Z SetHeatingPoint 20
2024-04-05T14:07:20.100773511Z TemperatureMeasurement 20.21
2024-04-05T14:08:13.281285434Z PIHeatingDemand 0x43
2024-04-05T14:09:49.046122981Z SetHeatingPoint 20
2024-04-05T14:12:22.441120203Z TemperatureMeasurement 20.16
2024-04-05T14:13:15.311912970Z PIHeatingDemand 0x44
2024-04-05T14:14:51.155195617Z SetHeatingPoint 20
2024-04-05T14:17:25.329854789Z TemperatureMeasurement 20.1
2024-04-05T14:18:17.591472706Z PIHeatingDemand 0x45
2024-04-05T14:19:53.389945101Z SetHeatingPoint 20
2024-04-05T14:21:26.240478614Z SetHeatingPoint 20.5
2024-04-05T14:21:27.257457433Z SetHeatingPoint 20.5
2024-04-05T14:22:27.009876678Z TemperatureMeasurement 20.08
2024-04-05T14:23:19.901526417Z PIHeatingDemand 0x44
2024-04-05T14:25:57.669877852Z SetHeatingPoint 21.5
2024-04-05T14:27:20.256624945Z TemperatureMeasurement 20.19
2024-04-05T14:28:14.957117743Z TemperatureMeasurement 20.33
2024-04-05T14:28:22.059682494Z SetHeatingPoint 20.5
2024-04-05T14:28:22.219955244Z PIHeatingDemand 0x09
2024-04-05T14:33:17.555858032Z TemperatureMeasurement 20.27
2024-04-05T14:33:24.009875158Z SetHeatingPoint 20.5
2024-04-05T14:33:24.582906158Z PIHeatingDemand 0x0A
2024-04-05T14:38:19.428819736Z TemperatureMeasurement 20.2
2024-04-05T14:38:26.291786903Z SetHeatingPoint 20.5
2024-04-05T14:42:20.021854699Z PIHeatingDemand 0x0B
2024-04-05T14:43:21.850828206Z TemperatureMeasurement 20.19
2024-04-05T14:43:28.946471040Z SetHeatingPoint 20.5
2024-04-05T14:47:22.411008152Z PIHeatingDemand 0x0C
2024-04-05T14:48:24.019727034Z TemperatureMeasurement 20.13
2024-04-05T14:48:30.885099201Z SetHeatingPoint 20.5
2024-04-05T14:52:24.662249379Z PIHeatingDemand 0x0D
2024-04-05T14:53:26.361168866Z TemperatureMeasurement 20.12
2024-04-05T14:53:33.281752138Z SetHeatingPoint 20.5
2024-04-05T14:58:20.113712753Z PIHeatingDemand 0x0E
2024-04-05T14:58:28.705172379Z TemperatureMeasurement 20.11
2024-04-05T14:58:35.565412589Z SetHeatingPoint 20.5
2024-04-05T15:03:22.332221126Z PIHeatingDemand 0x0F
2024-04-05T15:03:30.914921473Z TemperatureMeasurement 20.08
2024-04-05T15:03:37.799881182Z SetHeatingPoint 20.5
2024-04-05T15:08:24.661416433Z PIHeatingDemand 0x11
2024-04-05T15:08:33.245365851Z TemperatureMeasurement 20.04
2024-04-05T15:08:40.119944893Z SetHeatingPoint 20.5
2024-04-05T15:13:26.971087152Z PIHeatingDemand 0x13
2024-04-05T15:13:35.541097058Z TemperatureMeasurement 20.03
2024-04-05T15:13:42.419935051Z SetHeatingPoint 20.5
2024-04-05T15:18:29.435032272Z PIHeatingDemand 0x15
2024-04-05T15:18:37.949948939Z TemperatureMeasurement 20
2024-04-05T15:18:44.915074607Z SetHeatingPoint 20.5
2024-04-05T15:23:31.550831349Z PIHeatingDemand 0x17
2024-04-05T15:23:40.286575516Z TemperatureMeasurement 19.96
2024-04-05T15:23:47.005234142Z SetHeatingPoint 20.5
2024-04-05T15:28:33.860016439Z PIHeatingDemand 0x1A
2024-04-05T15:28:42.449906857Z TemperatureMeasurement 19.94
2024-04-05T15:28:49.364577608Z SetHeatingPoint 20.5
2024-04-05T15:30:00.108983296Z SetHeatingPoint 19
2024-04-05T15:33:36.449171520Z PIHeatingDemand 0x1C
2024-04-05T15:33:44.799862878Z TemperatureMeasurement 19.93
2024-04-05T15:33:52.059606441Z SetHeatingPoint 20.5
2024-04-05T15:38:38.480971160Z PIHeatingDemand 0x1F
2024-04-05T15:38:47.373793370Z TemperatureMeasurement 19.9
2024-04-05T15:38:53.943340787Z SetHeatingPoint 20.5
2024-04-05T15:43:40.771668878Z PIHeatingDemand 0x21
2024-04-05T15:43:49.339678087Z TemperatureMeasurement 19.91
2024-04-05T15:43:56.209880505Z SetHeatingPoint 20.5
2024-04-05T15:48:43.121004980Z PIHeatingDemand 0x24
2024-04-05T15:48:51.691275440Z TemperatureMeasurement 19.89
2024-04-05T15:48:58.855154899Z SetHeatingPoint 20.5
2024-04-05T15:53:45.451432773Z PIHeatingDemand 0x26
2024-04-05T15:53:54.036083593Z TemperatureMeasurement 19.85
2024-04-05T15:54:00.907700692Z SetHeatingPoint 20.5
2024-04-05T15:58:47.681454474Z PIHeatingDemand 0x29
2024-04-05T15:58:56.272205058Z TemperatureMeasurement 19.86
2024-04-05T15:59:03.139863601Z SetHeatingPoint 20.5
2024-04-05T16:03:49.962065360Z PIHeatingDemand 0x2B
2024-04-05T16:03:58.539839528Z TemperatureMeasurement 19.87
2024-04-05T16:04:05.405037821Z SetHeatingPoint 20.5
2024-04-05T16:08:52.337302255Z PIHeatingDemand 0x2E
2024-04-05T16:09:00.920531256Z TemperatureMeasurement 19.81
2024-04-05T16:09:07.758763507Z SetHeatingPoint 20.5
2024-04-05T16:13:54.721700884Z PIHeatingDemand 0x30
2024-04-05T16:14:03.349863604Z TemperatureMeasurement 19.83
2024-04-05T16:14:10.169950397Z SetHeatingPoint 20.5
2024-04-05T16:18:56.981163132Z PIHeatingDemand 0x33
2024-04-05T16:19:05.559675954Z TemperatureMeasurement 19.81
2024-04-05T16:19:12.434956794Z SetHeatingPoint 20.5
2024-04-05T16:23:59.395493044Z PIHeatingDemand 0x35
2024-04-05T16:24:07.850036617Z TemperatureMeasurement 19.79
2024-04-05T16:24:14.792037298Z SetHeatingPoint 20.5
2024-04-05T16:29:01.512935704Z PIHeatingDemand 0x38
2024-04-05T16:29:10.469637288Z TemperatureMeasurement 19.82
2024-04-05T16:29:16.989919664Z SetHeatingPoint 20.5
2024-04-05T16:34:03.812480034Z PIHeatingDemand 0x3A
2024-04-05T16:34:12.394863577Z TemperatureMeasurement 19.83
2024-04-05T16:34:19.269873161Z SetHeatingPoint 20.5
2024-04-05T16:39:06.102804303Z PIHeatingDemand 0x3D
2024-04-05T16:39:14.675127638Z TemperatureMeasurement 19.84
2024-04-05T16:39:21.960801472Z SetHeatingPoint 20.5
2024-04-05T16:44:08.411848393Z PIHeatingDemand 0x3F
2024-04-05T16:44:16.997908061Z TemperatureMeasurement 19.85
2024-04-05T16:44:23.881728895Z SetHeatingPoint 20.5
2024-04-05T16:49:10.691296756Z PIHeatingDemand 0x42
2024-04-05T16:49:19.323480299Z TemperatureMeasurement 19.86
2024-04-05T16:49:26.139863216Z SetHeatingPoint 20.5
2024-04-05T16:54:13.022329186Z PIHeatingDemand 0x44
2024-04-05T16:54:21.587051309Z TemperatureMeasurement 19.84
2024-04-05T16:54:28.445275565Z SetHeatingPoint 20.5
2024-04-05T16:59:15.371356914Z PIHeatingDemand 0x47
2024-04-05T16:59:23.925346898Z TemperatureMeasurement 19.79
2024-04-05T16:59:30.799937351Z SetHeatingPoint 20.5
2024-04-05T17:04:17.691626003Z PIHeatingDemand 0x49
2024-04-05T17:04:26.324340879Z TemperatureMeasurement 19.83
2024-04-05T17:04:33.195150713Z SetHeatingPoint 20.5
2024-04-05T17:09:19.980885198Z PIHeatingDemand 0x4C
2024-04-05T17:09:28.545052907Z TemperatureMeasurement 19.78
2024-04-05T17:09:35.445199074Z SetHeatingPoint 20.5
2024-04-05T17:14:22.593592247Z PIHeatingDemand 0x4F
2024-04-05T17:14:30.855229155Z TemperatureMeasurement 19.78
2024-04-05T17:14:37.799837614Z SetHeatingPoint 20.5
2024-04-05T17:19:24.603779139Z PIHeatingDemand 0x51
2024-04-05T17:19:33.451098130Z TemperatureMeasurement 19.78
2024-04-05T17:19:40.029921107Z SetHeatingPoint 20.5
2024-04-05T17:24:26.892670963Z PIHeatingDemand 0x54
2024-04-05T17:24:35.469874009Z TemperatureMeasurement 19.8
2024-04-05T17:24:42.339850470Z SetHeatingPoint 20.5
2024-04-05T17:29:29.180674706Z PIHeatingDemand 0x56
2024-04-05T17:29:37.757635707Z TemperatureMeasurement 19.79
2024-04-05T17:29:45.020141167Z SetHeatingPoint 20.5
2024-04-05T17:34:31.626599665Z PIHeatingDemand 0x59
2024-04-05T17:34:40.509921232Z TemperatureMeasurement 19.79
2024-04-05T17:34:47.054987964Z SetHeatingPoint 20.5
2024-04-05T17:39:33.934500270Z PIHeatingDemand 0x5B
2024-04-05T17:39:42.499230638Z TemperatureMeasurement 19.73
2024-04-05T17:39:49.369849195Z SetHeatingPoint 20.5
2024-04-05T17:44:36.202753411Z PIHeatingDemand 0x5E
2024-04-05T17:44:44.699857526Z TemperatureMeasurement 19.74
2024-04-05T17:44:51.572942890Z SetHeatingPoint 20.5
2024-04-05T17:49:38.401935222Z PIHeatingDemand 0x60
2024-04-05T17:49:46.986399640Z TemperatureMeasurement 19.77
2024-04-05T17:49:53.845187224Z SetHeatingPoint 20.5
2024-04-05T17:54:40.745232188Z PIHeatingDemand 0x63
2024-04-05T17:54:49.359934183Z TemperatureMeasurement 19.81
2024-04-05T17:54:56.179867345Z SetHeatingPoint 20.5
2024-04-05T17:59:43.030325242Z PIHeatingDemand 0x64
2024-04-05T17:59:51.600986993Z TemperatureMeasurement 19.82
2024-04-05T17:59:58.469886494Z SetHeatingPoint 20.5
2024-04-05T18:04:53.834711365Z TemperatureMeasurement 19.81
2024-04-05T18:05:00.835652228Z SetHeatingPoint 20.5
2024-04-05T18:09:56.574400372Z TemperatureMeasurement 19.81
2024-04-05T18:10:03.045411540Z SetHeatingPoint 20.5
2024-04-05T18:14:58.459863568Z TemperatureMeasurement 19.81
2024-04-05T18:15:05.345149486Z SetHeatingPoint 20.5
2024-04-05T18:20:00.811119657Z TemperatureMeasurement 19.79
2024-04-05T18:20:07.729889366Z SetHeatingPoint 20.5
2024-04-05T18:25:03.150861809Z TemperatureMeasurement 19.81
2024-04-05T18:25:10.015200976Z SetHeatingPoint 20.5
2024-04-05T18:30:05.400494279Z TemperatureMeasurement 19.75
2024-04-05T18:30:12.277888197Z SetHeatingPoint 20.5
2024-04-05T18:35:07.715187794Z TemperatureMeasurement 19.75
2024-04-05T18:35:14.602651389Z SetHeatingPoint 20.5
2024-04-05T18:40:10.105372650Z TemperatureMeasurement 19.75
2024-04-05T18:40:16.969924741Z SetHeatingPoint 20.5
2024-04-05T18:45:12.395001298Z TemperatureMeasurement 19.75
2024-04-05T18:45:19.215421632Z SetHeatingPoint 20.5
2024-04-05T18:50:14.681672349Z TemperatureMeasurement 19.75
2024-04-05T18:50:21.529908767Z SetHeatingPoint 20.5
2024-04-05T18:55:17.082089351Z TemperatureMeasurement 19.75
2024-04-05T18:55:24.229871673Z SetHeatingPoint 20.5
2024-04-05T19:00:19.575020816Z TemperatureMeasurement 19.75
2024-04-05T19:00:26.209864873Z SetHeatingPoint 20.5
2024-04-05T19:05:21.642342937Z TemperatureMeasurement 19.75
2024-04-05T19:05:28.495268094Z SetHeatingPoint 20.5
2024-04-05T19:10:23.877911959Z TemperatureMeasurement 19.75
2024-04-05T19:10:30.770881835Z SetHeatingPoint 20.5
2024-04-05T19:15:26.230888942Z TemperatureMeasurement 19.75
2024-04-05T19:15:33.099863734Z SetHeatingPoint 20.5
2024-04-05T19:20:28.519840853Z TemperatureMeasurement 19.74
2024-04-05T19:20:35.379936437Z SetHeatingPoint 20.5
2024-04-05T19:25:30.929866235Z TemperatureMeasurement 19.73
2024-04-05T19:25:37.759853981Z SetHeatingPoint 20.5
2024-04-05T19:30:33.169102566Z TemperatureMeasurement 19.74
2024-04-05T19:30:40.050941650Z SetHeatingPoint 20.5
2024-04-05T19:34:27.011205321Z SetHeatingPoint 34.5
2024-04-05T19:35:35.609821187Z TemperatureMeasurement 19.74
2024-04-05T19:36:20.424444505Z TemperatureMeasurement 20
2024-04-05T19:37:20.221798221Z TemperatureMeasurement 20.1
2024-04-05T19:38:56.908105982Z PIHeatingDemand 0x64
2024-04-05T19:39:29.233777273Z SetHeatingPoint 34.5
2024-04-05T19:42:20.106674479Z TemperatureMeasurement 19.99
2024-04-05T19:44:20.089855840Z TemperatureMeasurement 20.11
2024-04-05T19:44:31.985197779Z SetHeatingPoint 34.5
2024-04-05T19:46:20.058139346Z TemperatureMeasurement 20.29
2024-04-05T19:47:20.081622534Z TemperatureMeasurement 20.4
Yes, can see perfectly in the logs how the valve opens or closes progressively to reach the HeatSetPoint temperature.
The capability operstingStste does not allow any value to be able to show the % opening of the valve.
I could use the capability switch level to show % valve opening from 0% to 100%
