Be careful about the 3- 2 foot strips, they are for different length adjustments, it will not come with the necessary equipment to have 3 independent strips connected out of 1 box. To do that you would need 3 power supplys. But if the cabinets on the Murphey bed are next to each other you could drill a small hole to string this through.
Again I don’t own this product so someone who does correct me if i’m wrong. =)
Oh so they are meant to be connected together? Thanks!
One other question as I was reading another thread on them: do I need the controller for them? @JDRoberts, I was on a thread you were on about these (still reading). Can these be paired directly to the ST hub or the hue hub? I saw on BB’s they have an expansion kit which is only $29, I would love to try that one.
Thanks,
Scott
So after researching a bit I think I now understand how they work, I was confusing the Controller with the Gateway. The Gateway is not needed as the devices will connect directly to the ST hub, but the controller, which is the Zigbee connection, connects to the power. The expansion pack I mentioned just extends the pack mentioned above and does not include the power connector or controller.
It also looks like you can connect up to 30’ to one controller, each strip looks to be 2’ in length.
Do I have that right?
This looks like a really cool product and I am already looking at the GardenSpot for outside around my deck It figures I come here to find a simple solution to adding controllable lights to one room and now I have many more plans for more $$$
The only thing I dont like is it looks like then do not sell the controller and power adapter separately so you could just connect separate 2’ sections.
I may pick up the kit after work from BB and will let you know how it works out.
They don’t sell just the controllers, but if you’re ok with three separated strips all controlled together, they do have this connector kit: http://amzn.com/B0142T2HW8. Almost no details on the amazon listing, but it comes with “2 - 1ft universal connectors, 2 - 3ft universal connectors, 2 - 5ft universal connectors, 2 - 10ft universal connectors and 2 rigid connectors, 2 Flex to Mosaic connectors” according to their online catalog
That would be helpful because my idea was to run one strip under each shelf and to do that I would have to run a lighted portion of the strip up the side (back) portion of the shelving unit to get to the underside of the next shelf. This would allow me to run the extension cable semi-hidden in it’s place and then connect to the next strip under the next shelf.
It’s just too bad they did not sell these is smaller quantities or individually, can’t have it all
I may get the kit and decide from there if I want to spend another $30 on this. I would be able to use the leftovers if I bought another light strip set for somewhere else.
Just an update on this. I did buy the Osram kit from BB and connected all 3 together around the back of her bed.
She LOVES it!!!
Her only complaint right now is she has to open her phone app just to turn them on and would like a button or switch she can just hit to turn the lights on (full,white) and off. Then if she wanted colors she could just open the app.
I had bought a Minimote to assist with my V2 hub migration and may just give her that. I could set 1 button for on, 1 for off and maybe the other 2 with a predefined color.
I know there are battery powered buttons out there (like scene controllers) but are there just single push buttons yet?
Most door window sensors have a normally open contact on them, you could make a housing and wire a regular push button switch to the contact. but a v1 minimote is probably less expensive and looks better.
Then associate the door contact to toggle the light
My suggestion would be to build the color cube for her. If she has a place for it to sit on her shelf. My guess is that most teenagers would love this. There are six sides on a cube, so you end up with six possible functions, one of which will be off.
Let her help build it, and it’s a great introduction to three-dimensional physics. And a practical light control on top of that.
You do you need a multisensor that has an accelerometer, so that’s a cost, but for the price of two Minimotes you get a super cool light control and A really interesting practical science project.
Alternatively, the $15 securifi key fob has three buttons. It’s tiny, though, so you might want to hang it on a hook so it doesn’t get lost.
Great idea and yeah I should involve her in building it. I think I may have to do that and the cost is minimal.
Do you have a recommendation on a multi sensor?
I think most people just use the SmartThings multisensor, but any ST-compatible acceleration sensor that has an XYZ capability will work. That’s really all you’re doing, grabbing the orientation along three axes. You might ask in the mood cube topic and see what people have used.
