First things first, I am going ot post the links to, not just the images because the site limits the display size of the images, so follow to the images and zoom in for a better view…
After trying ot install 2 3 way smart switches in my 1984 construction house, I have come to the following conclusions.
#1. The original electrical contractor, or whomever was in these wires at whatever point doing this work must have been a drunken babboon. I am sure they are “functional” workarounds and cost cuts, but they sure aren’t right… These sort of obvious shortcuts are prevalent throughout this house, as they are in most homes in my neighborhood.
#2. The city building inspector from when my home was built MUST have been on the take, or absolutely incompetent. Okay in all fairness, odds are electrical code has to have changed quite a bit since 1984, but… wow this is bad.
In box 1, the power comes in from the black wire on the left, now here is where it gets wierd. And I need to re-check myself here on that power, because the other way makes MUCH more sense… But the white wire that is coming in on that same cable / romex is attached to one of the traveller lugs.
Looking at the photo more, I NEED to double check the voltage again, per Leviton’s video descriptions, the brass colored screws are traveller lugs / wires, so it would make sense if the black, AND white from that romex were both travellers, and the black from the romexes on the right are line power… But then again, 2 light fixtures here (recessed cans) if they went parallel instead of series wiring, this COULD theoretically be load, but…
As I talk this through here, it makes more sense that way, I MUST verify this.
Box 2, gets power from the black on the left if box 1 is populated and turned on. No power if disconnected from box 1. What I find freakishly weird is that there is an extra white conductor in this box coming in from the right (zoom in and you’ll see).
That ties into the white wire from the romex on the right making me think this is where the circuit is picking up a neutral, and thus, this should in THEORY be the romex for the load (?)
Now, if the power comes in on that box 1 left side black conductor, I am flumoxed as to what to do.
IF on the other hand, box 1 power comes in from the romex on the right on the black conductor, that helps identify BUT leaves me with the same problem I had before, how to wire this up with only 14/2 going between the boxes…
Now, having said that, the good, and the bad.
The good,
- There is less than 16’ total up the wall, accross the ceiling, and down the opposite wall between boxes. It is a trivial matter to pick up a 25’ 14/3 with ground romex from Home Depot.
- The headers for these walls are super easy to get to from the attic. Going through the attic and into the fixtures themselves should be a simple task.
The bad,
- Somehow the managed to pay attention to code when it came to stapling romex to the studs, which means back pulling these wires is not possible.
- My wife wants ot keep the wallpaper that we have, and being is it’s wallpaper, not like it is going to be easy to find and replace this stuff…
Like I have said before, I am not adverse to pulling new cable when it warrants it, BUT, especially in this particular bathroom, I do NOT want to be redoing sheet rock and finish due to the wallpaper.
What are my options?
