The problem is that almost all of the Z wave and zigbee switches that work with SmartThings do require a neutral. In fact, I think all of the switches on the official “works with SmartThings” list require a neutral.
There used to be GE zwave dimmer switches that did not, but they have been discontinued because, like most similar switches, they only work with incandescent bulbs. And these days everybody wants dimmable LEDs.
Cooper still makes one z wave model that does not require a neutral, but again, it only works well with incandescent bulbs.
Lutron makes excellent networked switches that do work with dimmable dumb LEDS, their Caseta line, but unfortunately SmartThings has never added direct support for Lutron. You can get indirect support through IFTTT, and that is much discussed in the forums, The short answer is it will work OK for anything except when you want to have a SmartThings controlled motion sensor turn on the Lutron switch. Then the lag may be too long.
Smartbulbs like Phillips Hues are the easy solution. You can certainly put three of those in one fixture. No neutral required. Then you have to figure out what to do about the light switch but we have an FAQ for that.
But as far as smart dimmer switches themselves, while it is true that there are some on the marketplace that do not require a neutral, there aren’t any that work directly with SmartThings except for the Cooper, and while it’s a good switch, it doesn’t work well with LEDs.
