Hub v2 Antenna Orientation
Thanks for the clarification. I was confused for a while there.
Cheers
Sorry to resurrect an old thread, but Iā€™m experimenting with placements for my hub - I live in an apartment, but have access to the attic so I have some flexibility with running wiresā€¦ within reason (what I can fix later with drywallā€¦). I noticed in the labeled pics, thereā€™s 4 small solder pads for the antennas for zigbee and bluetooth. While the bluetooth isnā€™t of much interest at the moment (since its not implementedā€¦), the zigbee oneā€¦ could a surface mount u.fl (I think thats the right name for it) antenna connector be placed there and an external antenna added? For that matter, the z-wave antenna is certainly easy to get at too (different frequencies obviously) - just thinking about ways to get the antennas away from the board and/or add external antenna ā€˜optionsā€™ - Iā€™m not an RF guy, but I know a little (except terminology apparently).
Iā€™m guessing ST staff isnā€™t going to reveal much on this one :slight_smile: but Iā€™m not opposed to modifying things even if its not quite as aesthetically pleasing.
Old thread I know but I always end up here so I might as well add a vanity post and try to help. Quick tear down of the Samsung SmartThings WiFi V2 (model ET-WV525). Since I have 4 I plan on tricking out one and adding some external antennas. The last photo has the antennas Iā€™m going to test.
The uFl connectors for the WiFi can be seen labeled 5G CH0 / 5G CH1 / 2.4G CH0 / 2.4G CH1
It seems that the current antennas are slivers of metal attached to the topside of the plastic housing
Did you have any luck adding external antennas?
