I have a fully functioning v1 setup at one home that I have used for a couple of years mainly to control GE Link bulbs. The settings for those bulbs (in the app that I use to turn them on at sunset) has a place where I can specify the dimmer setting. I never used that, but now I am setting up another home using the v2 hub that I got the $99 deal on. Problem is I can’t seem to figure out where the setting for the dimmer level went. The SmartThings recommended SmartLighting app doesn’t seem to have that setting. Is there any way to get it back? I want to turn on the bulbs at sunset with the dimmer level set to 50% (and then turn them off at sunrise).
I also can’t seem to figure out how to create a virtual switch. At the v1 home I have 6 bulbs linked together using a virtual switch called “Outside Lights” and can turn them all on or all off using the switch. How do you do that with v2?
bc
