Hub restart - behaviour of drivers/devices
Hi,
Is there any info regarding the behaviour of drivers/devices in the event of a hub reboot?
I have some code in a spawned coroutine, but I ‘think’ on restart it needs to respawn…Lots of ways to fix, just wondering if there is any ‘Hub has been restarted, need to respawn stuff’ event or flag is set
Tagging @andresg
On restart all your drivers will go thru their init routines again. Do any work there.
Hi, @Davec
The driver_lifecycle can be used for that purpose. The second argument is the string name of the event and you can set it to"shutdown"
Hi, @Davec
Here is the documentation about driver_lifecycle
Ok Thanks I will give it a try
So when a hub is rebooted the shutdown event isn’t called (I don’t think)
@csstup suggestion to use init seems good.
