What is the NetworkSecurityLevel for the devices that you try to change their configurations?
Hey, Sorry that I cannot give an exact date, because things are fluid but we are looking at mid to late May.
All of my Fibaro (Dimmer 2 and Single Switch 2) devices show a NetworkSecurityLevel of
ZWAVE_S0_LEGACY
Same for the device I āmovedā to my V3 hub for testing.
Should it be something else? How would I modify the NetworkSecurityLevel?
Well, Letās continue this conversation in the PM.
Are you confident that the problem lies in code changes to the back-end cloud server (and/or that codeās interaction with recent 25.26 and 25.27 firmware)?
Is there a reason you cant āroll backā those changes, as was done in early March before the 25.26 update?
Finally (and perhaps more importantly), is there any reason to migrate (or not to migrate) devices from V2 hub to V3 hub?
I am leaning toward waiting until you resolve this issue in mid-late May since I can work around the āsync problemā temporarily by using Z-Wave Tweaker to change/sync the parameters.
By the way, does anyone know why the Z-Wave Tweaker workaround enables the parameter sync, while the standard Fibaro DTH does not? Does Z-Wave Tweaker avoid using the back-end cloud server?
Sorry for all the questions (and for being a bit impatient for a fix).
Just want to understand these issues a bit better.
Hello - I have recently noticed the following when trying to run a zwave repair. I have a 2Gig 3GC Panel connected to my ST setup as a secondary controller - the 2gig panel is showing error ācheck devicesā now as well it seems to be related
Also on the 2gig panel it is showing unknown device 11 - 14. In ST I only have devices 3,4,8,9. I am not sure where 11-14 come from, and is there a way to free up 5,6,7? Or is there any reason too? Thank you for your help!
Iām on 25.26 and have the same issues. Everything is going haywire and very slow to turn on and off. Sometimes just stopped working all together. .Every time I run Z-wave repair different devices show errors.
Network repair for Floor Fan [4D]: Could not delete old routes
Network repair for Sub Woofer [4C]: Could not assign new route
Network repair for Sub Woofer [4C]: Could not delete old routes
Network repair for Floor Fan [4D]: Could not assign new route
Iāve removed them and re set them up still get errors. Not sure whatās going on, but if itās a firmware they need to fix this and fast.
So how long do we have to wait for it to be released to us?
Your guess is as good as mine.
I just got hit with this bug/issue. One of my GE switches stopped working and I guess it was a pretty important neighbor for a lot of other stuff, so basically half of my house stopped working. Pretty neat. Hopefully this can be resolved soon.
You may want to post in the most recent firmware release thread ![]()
Thanks. Iām on the new firmware but I think the update is actually what caused the issues!
Since 0.25.32 has now been released please use this thread for future comments: Hub Firmware Release Notes - 25.32.
