Regarding which, sadly, we are given even less information. Hub updates are much better documented/shared with the user community!
Wouldnāt changes to Z-Wave structure be local? Platform changes are merely a storage problem, but how the hub handles Z-Wave devices must come through firmware updates. Thinking out loud hereā¦
Nope. Thereās a cloud component for the abstraction layer. Thatās why your Custom DTHs can run in the cloud.
Hey Guys,
Iām in Australia and have the SmartThings Wifi, Plume AU Hub and am still on 24.00052
Any ideas when iāll get a software update to this device?
Thank your stars for not getting this buggy update.
Any progress? Itās been almost a month since this bug was introduced and itās still not fixed.
Again, I donāt want to be pain in the ass, but I take smart home and home security very seriously, and SmartThings is simply not reliable at this point. Your attitude with forced updates and zero possibility to rollback is the key problem here, not that somebody messed up, thatās normal in software engineering.
You simply cannot introduce major bug, which renders some smart home devices unusable and say: āYeah, we know, whereās the issue, but we cannot tell you, when itās going to be fixed.ā and then nothing happens in a month?!
Yeah the issue still exists. Iāve got a hub disconnected message 40 minutes ago. I can still control all my devices and the app doesnāt show it disconnected either. Still havenāt received any follow up itās online message as yet even though everything is working.
Ever since the firmware got updated to 25.26, my Schlage Camelot Z-wave locks stopped sending any messages. I have reinstalled lock DTHs, Lock Manager, deleted the sophisticated DTH and tried the simple one, installed Smart Locks, rebooted everything multiple times. I am out of basic and semi-pro ideas.
Can anybody advise? Itād be great if a staff member could look into my hub remotely and tell me whatās going on.
Additional info: I have V2 hub. The locks can still be controlled (locked/unlocked, armed etc.) though Smartthings Classic app, they just donāt send a message back with the used codes, manual lock/unlock etc.
See my post here: [OBSOLETE] Lock Manager - #2045 by Babar_Khan
You guys will never get a switch to allow firmware updates unless they totally abandon the cloud architecture, so please stop asking. With the cloud, they only want to make the cloud work with the current and the previous firmware version.
Which means that theyāve coupled the two parts too tightly.
I understand, that they tightly coupled their cloud with hub firmware. I donāt agree with it, but I understand that.
Hereās a question ā why they didnāt rollback both firmware and cloud API implementation, since itās broken as hell?
I have to constantly walkthrough people, how to fix their devices, because I am the unlucky creator of the DTH. Not to mention, that Iāve lost something around thirty hours trying to debug my DTH pointlessly, since the error was all along on the Samsung side of things. I might have catch that, but you know, silent updates are a thing.
I have done some more troubleshooting on this issue, which I just posted in the Devices and Integrations section (under my original post about "Fibaro Light Switches NO LONGER SYNC . . . ).
If Tom Manley is monitoring this forum, I am hoping he will see this post.
In short, I added a V3 hub (to a new location - shows current 25.27 firmware) along with my V2 hub -(which only shows 25.26 firmware) - did not fix the problem. I removed a Fibaro Dimmer 2 from my V2 hub and added it to the V3 hub, but the problem remains the same (will not SYNC config parameter change without using Zwave Tweaker).
My Fibaro Motion sensor doesnāt synch either any more if using the new local DTH, nor reports on motion. Are these related to this last firmware release?
I see on my Fibaro device it is saying * networkSecurityLevel: ZWAVE_S0_FAILED
I suspect it is related to some back-end cloud server changes made by Smartthings in connection with the recent firmware updates (25.26 for V2 hubs and 25.27 for V3 hubs). Samsung maintains a status page at status.smartthings.com which details some of these issues.
Sounds like the Smartthings engineers are aware of these problems, but havent yet found/implemented a solution.
They have moved on since programmers canāt seem to get anything working it seems to me. SmartThings was then actually was working decent for a very short period followed by the current decline is getting aggravating. It seems like they try something & when it doesnāt work move to something else and no thoughts to customers who have spent a lot of money on current products.
We have a fix for this issue and are going to include that in a release in the near future. Timing of the release is TBD, but it is planned for mid to late April (leaning towards late April).
Polite request for any news on this please.
I second the polite request. That would be great.
Out of curiosity, my new V3 hub shows firmware 25.27, while my V2 hub still shows 25.26.
Both exhibit this same problem.
But Iām wondering whether Smartthings (or someone else on this forum) can confirm whether different firmware updates are released to V2 v V3 hubs, or are both hub versions treated the same in this regard?
We have released 0.25.27 only to hubs that were experiencing the issue described in the following post Recap: If your hubās Z-Wave Node ID was NOT 0x01, you most likely have been experiencing communication problems with only secure Z-Wave devices on 0.25.26 release (not all Z-Wave devices use security to transfer messages). We fixed that issue in 0.25.27 and pushed that change to only hubs that were experiencing this particular issue. You can determine if your hub had this issue by checking the Node ID of your hub, by checking the Z-Wave section of the hub info page (https://graph.api.smartthings.com). For example: [image] How do you determine if a device uses security? If the raw description of your Z-Wave device has āsā (lower case) in the āzw:ā section, then the device uses seā¦
I too have .27 on V3 and .26 on V2 and this is how it should be, as described in post above this one.
