Http HubAction in devicetype isn't calling parse()
Because raw socket hubactions won’t actually return results, I’ve started writing a http based middle layer. I can’t figure out how actually retrieve the response. I thought it should come back in the parse() function but as far as I can tell its not being called.
I’ve tried both methods of HubAction
def poll() {
    def pollAction = new physicalgraph.device.HubAction(
    		method: "POST",
    		body: body
    		path: "/send/<ip>/10002?timeout=1001",
    		headers: [HOST: "<ip>:54231", 'Content-type': 'application/json']
    pollaction
and
def poll() {
    def pollAction = new physicalgraph.device.HubAction("""POST /send/<ip>/10002?timeout=1002 HTTP/1.1\r\nContent-Length: ${bodyLength}\r\nContent-type: application/json\r\nHOST: <ip>:54231\r\n\r\n${body}\r\n""", physicalgraph.device.Protocol.LAN, "${deviceNetworkId}")
    pollAction
Looking at a network dump (using ngrep)
  HTTP/1.1
  Content-Length: 40
  HOST: <ip>:54231
  ["<username>\r", "<password>\r", "POWR?   \r"]..
Response:
  HTTP/1.1 200 OK
  X-Powered-By: Express
  Content-Type: application/json; charset=utf-8
  Content-Length: 43
  X-Response-Time: 1005.299ms
  Date: Thu, 18 Sep 2014 04:32:28 GMT
  Connection: keep-alive
  ["Login:","\r\nPassword:","\r\n1\r","\r\n"]
I’m stuck as well. I see people using parse, but I cant get it to fire.
To receive HTTP response your deviceNetworkId must be set properly.
You’re the man. I also had to convert the ip to hex, and then copy that hex into the device properties screen for the networkid.
Any advice on how to let parse know which request it is parsing? I am assuming this is asynchronous, so how can I send a tag or identifier with the request that I can read in parse() to know what request I am parsing?
Implement a state machine or just save your last request in the state variable.
@geko you can use ‘state’ variable in a DeviceType? I only saw it as part of smartapp documentation. any examples?
Easy peasy, state.foo = "bar"
Then later if (state.foo == “bar”) punt…
Haha, thanks Mike! Don’t I feel foolish…
Shouldn’t, I’ve spent hours trolling device code trying to understand and remember these tid-bits…
I dont see how that would help:
Req1, state = req1
req2, state = req2
req1 response comes in, state = req2
