I’m having a difficult time getting my device handler to poll a local REST endpoint I have set up.
In my “installed()” and “updated()” methods, I have a
runEvery1Minute("poll")
Then I have a poll method:
def poll() {
return new physicalgraph.device.HubAction(...
finally I have a parse method that is supposed to consume the result of the request
On my local server I am logging all incoming requests. However, I am not seeing these requests come in ever. I can trigger the request to fire if I put the HubAction in a different method and trigger it manually. But it doesn’t seem to work within a schedule ?
Does anybody have any ideas what I might be doing wrong ?
RBoy
#2
When a command method of your Device Handler returns an instance of a HubAction,
the SmartThings platform will use the request information within it to actually perform
the request. It will then call the device-handler’s parse method with any response data.
If I use sendHubCommand(hubAction), does that mean I don’t need to return it from the command ?
Right now I have a local server running that returns a simple string.
When I call the sendHubCommand(hubAction), I just get a response of “{OK=NULL}” instead of my string.
Any ideas what this means ?
RBoy
#5
That only applies when the platform makes the call to the method or is user interactive initiated (button)
