BRK RM4 is a smoke detector relay. Whether you connect NO or NC depends on what device handler you used. If you use NO, the sensor will read as “open” until the alarm is triggered, then the relay will activate, that contact will close, and the sensor will change states. If you use NC, the sensor reads as “closed”, and opens on an alarm signal, again changing the sensor state.
The handler below includes a toggle; just pick one wire to connect, and if it doesn’t work as expected, flip the toggle (reversing the connection in software vs hardware).
I’m not an expert but I’m guessing it would be considered more “fail-safe” to use the NC connection. That way if something causes a loss of signal from the alarm/relay, ST is immediately triggered, whereas if you use the NO connection, the problem is hidden until the alarm goes off and ST fails to see it.
