you set it to not run in that mode by picking all Modes except for that one.
So, how do the different modes change? Is it automatic or do I have to manually change it on the SmartThings app? So, for example, if I do not want the light to turn on base on the motion sensor, do I manually change the mode on my phone then I can manually turn on the light switch?
You can manually change the mode or you can use an automation to change the mode.
I see. Okay, so I’ll put this here just for my own information.
