How to create Virtual switch for my Lightify Flex
So, i was able to create a virtual switch for each color, however, I want to create a routine that triggers those switches.
The problem is that I can’t activate that routine with Amazon Echo because Echo doesn’t recognize routines, only switches. However, I found a work around which is creating a virtual switch that triggers the routine.
So how would I do that?
Thanks so much
