How to collect SmartThings data
To do lead enrichment from SmartThings and import it into Excel or another chart-making option, you can follow these general steps:
SmartThings Developer Account:
    Make sure you have a SmartThings developer account.
    Log in to the SmartThings Developer Portal (https://developer.smartthings.com/).
Create a SmartApp:
    Create a SmartApp in the SmartThings Developer Portal.
    Configure the SmartApp to access the data you want to collect.
Generate API Token:
    Generate an API token that your application can use to authenticate with the SmartThings API.
Use the SmartThings API:
    Use the SmartThings API to retrieve data from your devices. You may need to use endpoints like https://api.smartthings.com/v1/devices/{deviceId}/status or other relevant endpoints depending on your requirements.
