A post was split to a new topic: Need Help with GE Wiring
Moved to split topicâŠ
Great. Could you share these instructions?
As of April 2017, there is now an official cloud to cloud integration with SmartThings and Lutron Caseta.
Any chance I could get someone to post a model number of the no neutral require Lutron switch?
Model # PD-6WCL-WH
The PD6WCL model is a dimmer switch that does not require a neutral. It can also be configured to act as an on/off switch. This is the switch that is usually included in the Lutron âstarter kitâ which also includes the Lutron SmartBridge which will be needed for SmartThings integration. ( when SmartBridge can handle up to 40 lutron devices.)
The model number will have an additional suffix, but that just applies to the color of the outer case.
http://www.casetawireless.com/Pages/Products.aspx
https://www.amazon.com/LUTRON-PD-6WCL-WH-Caseta-Wireless-Dimmer/dp/B00KLAXFQA
And of course the pico remote, which are used as auxiliary switches for three ways, do not require a neutral because they are battery-operated.
https://www.amazon.com/Lutron-PJ2-3BRL-WH-L01R-Control-Favorite-Setting/dp/B00KLAXFQ0/
Thank you!
Do you know if they make a on/off switch that works with two wires?
The switch with no neutral is PD-5WS-DV. They work flawless but make sure it come with the capacitor that crosses the load
