How do I Unify thread networks?
So when you went into the ST app, you were able to see the ST and the Aqara Thread networks in “Manage Thread network” and the option to “Join this hub to another…” was available under the Unify Thread Network?
That’s the strange thing. I have four different Thread networks and ST only shows the Thread network for the hub I’m looking at. Do you know if you Aqara and ST hubs are using the same Thread channel? I know my Eero and ST are on different channels, but I don’t know if that would affect or not.
Now that you have ST, Aqara and Apple on the same Thread TBR mesh what do you see on pairing a Thread device? Do you still get asked which TBR to use? Is still necessary to add from one system to another with Matter (as with Matter over Wifi)?
Platforms do not care how many TBR are or which vendors make them, it’s just the Thread network name and the credentials. If the network has only the SmartThings hub or two additional TBRs from other vendors doesn’t change anything.
Yes, that doesn’t change anything either, Thread just provides connectivity to your local network, like WiFi, but is independent of Matter.
To use Matter multi-admin you have to share the device from a smart home platform like always.
The only difference of having one or more TBRs in the same network is redundancy and reliability. For instance, if the only TBR in your Thread network is the SmartThings hub but share a device to Apple Home, if the SmartThings hub dies, Apple Home won’t be able to control the device anymore. However, if you have more TBRs in the same Thread network, even if the SmartThings hub dies, Apple Home will be able to communicate with the device using the other TBRs.
I’m having the issue with joining my ST Thread network to my AppleTV thread network. I deleted all Thread devices from ST (confirmed with the ST advanced settings that no devices are connected via Thread), but I still am not able to select “Join this hub to another service’s Thread network” under Unify Thread network. It is greyed out, and the only network listed in Manage Thread network is the ST network, which I cannot “leave”.
I also have a Google Home thread network, but when I got to Thread networks setting on Android, I see the preferred network is a Nest network and I see 2 “other networks” (what I think are the ST network and the AppleTV network) that I cannot select as preferred “Unavailable network: to access this network, set up this device with the manufacturer app you used to set up this network”). I’m not sure what to do… Any help?
release notes:
  • When merging a Hub’s Thread network into a 3rd party network, handle unexpected data in the Thread network settings that might have previously prevented the merge from succeeding.
also, is the Apple TV up-to-date with System updates?
Thank you! I will wait to see if 0.59.8 solves for me
my device updated to 0.59.8 but the same issue remained. I could not join another thread network even though no thread devices were currently set up on my SmartThings network. I’ve given up for now but if folks have other ideas, would welcome them.
I had to remove all devices, not just matter devices, from my ST hub for the “join another thread network” option to become selectable.
After that, I was able to join my ST hub to my unified Google thread network.
I am trying to join my Apple thread network, but there is no option to get 9 digit credentials from Apple . I read some documentation that smart things should invoke it from Apple keychain but this is not happening.
Anyone has a way to get the credentials
I have this same issue. I cannot join my brand new, empty SmartThings Smart Hub 2 thread network to my Apple Home. I have even tried updating my Apple TV’s and iPhone to tvOS and iOS 27 beta’s with no luck. Very disappointing. I have opened a ticket with Samsung support.
Samsung support was less than helpful. The said open a ticket with Apple. When I contacted Apple support, they were even less helpful than Samsung. I guess we’re in the hands of the software engineers now. God have mercy on our smarthomes.
There an API in iOS so that apps can join existing Thread Network. It relies on TBR that register using the same API. Apple, Eve and Nanoleaf are using it.
Samsung could use it if they wanted. It’s available in iOS 15 (2022) and Thread 1.3 devices. Create a ticket and ask them to use ThreadNetwork.framework and retreivePreferedCredentials method.
Starting from iOS 27 and tvOS 27 any Thread 1.4 TBR can as well get a 9-digit code for manually joining a thread network. I tested it with a small app done myself it works pretty well. Same framework but a new API named enableCredentialSharingModeWithExtendedPANID
Using current SmartThings app you’ll need to wait for release version of iOS and tVOS next October.
Noticing that with the 62.x firmware now, on trying to “Unify Thread network”, the option to “Join this hub to another Thread network” now shows in both my hubs.
Previously this was limited to a hub with no devices.
When Apple finally implement the One Time Passcode that will be an advantage.
