Hook 433/315 mhz brdge (Help this project!)
Anyone get one of these Hook devices working with light strips or other RF devices or are they limited to the wall outlets? Thanks!
They should work with anything that uses standard GROUP/CHANNEL/COMMAND type ON/OFF signals on 433MHz. Most all light strip controllers I’ve come across work outside of that range though.
These little guys definitely speak 433, I was able to integrate them with my Particle Photon RF Bridge. If Hook would support it? I’m not sure.
@keithcroshaw I have been using particle photon with ST. It is easy if you have your DH poll functions from particle.
I also got it working where particle can send events to ST but that is a bit more tricky to setup.
Ya know what i’d kinda like to get status reporting back from Particle… Ugh work…
