I used to use homeseer WD100+ devices with the OLD smartthings. I made a cross country move and now finally re-setting everything up hoping to get the Double and Triple tap functions back.
Before it used to be an ABC configurator app which did the trick, but looks like it no longer works with the updated SmartThings.
Hope that someone can help me to get all of my things re-set up.
When you installed it… did you look in Automations > + > Add Routine > click on the Discover tab and scroll down to find the app to set up? Or are you having other issue?
