Hi there,
I’ve been using a Hive ecosystem for the past few years, and have been generally quite happy with it.
It consists of a single zone thermostat and a range of bulbs, grouped into rooms, linked with Google Assistant for voice control. I don’t do much in the way of routines/automation yet, but may do in the future.
I’m looking at moving this year, and am considering options for migrating or replacing what I have in my new home. This is so if I need new gear, I can get it ordered ahead of time and installed as part of a new build.
I see SmartThings supports a lot of vendors’ devices, but Hive isn’t listed. Does anyone know if the Hive gear I have can work with SmartThings?
Would I still need the Hive hub in front of the Hive devices, or could the SmartThings hub replace this?
Does SmartThings support any kind of offline control of devices when the internet goes down?
Assume Nest is not currently supported?
Does SmartThings support multizone heating?
What would you do?
Any input you kind folk could provide would be greatly appreciated, so I can start investigating based on your suggestions.
Many thanks
Eds
