Dear all
I have search and have not found support for the above keyfob. Can anyone help with the device type?
kao
Dear all
kao
Not sure what country you’re in.
This device is zwave certified for Russia, not the US. I couldn’t find any indication that it’s been manufactured in a U.S. version, which is what you would need for SmartThings unless you got one of the initial European run from Kickstarter.
If you do have a European version of SmartThings or a US version of the Kfob, it still doesn’t support beaming, so you can’t use the Kfob with doorlocks.
It works by controlling 4 association groups.
But the first question is whether you have matching zwave frequencies. The U.S. zwave frequency starts with 9. Europe starts with 8. I’m also not sure if a russian frequency device would work with a European frequency device: they’re close but not quite the same.
HI JDRoberts
I am sorry for be so sparse with information.
I am using CE version of Smartthings. Hence the Zwave frequency is correct (868.5MHz). Zwave.me keyfob is also the European version. I have already had the keyfob associated with Smartthings. It just shows up as a generic device. I don’t have the device definition for the keyfob for it to trigger any event (still learning the IDE, so it will be a while before I can get anything workable)
kao
I just got this device - almost identical in setup to another one I had… so making the device handler wasn’t too hard. If it’s not to late for you here it is. To make it work you have to:
Pair device to smartthings normally
change the device type to this one
put key fob into inclusion mode again
press “configue” in the device on the app
Wait 30 sec after the flashing stops
Done
http://www.apache.org/licenses/LICENSE-2.0
metadata {
definition (name: “Secure Key Fob”, namespace: “Z-Wave.me”, author: “AdamV”) {
capability "Actuator"
capability "Button"
capability "Contact Sensor"
capability "Battery"
capability "Configuration"
capability “Refresh”
fingerprint deviceId: "0x1202", inClusters: "0x5E, 0x70, 0x85, 0x2D, 0x8E, 0x80, 0x84, 0x8F, 0x5A, 0x59, 0x5B, 0x73, 0x86, 0x72, 0xEF, 0x20, 0x5B, 0x26, 0x27, 0x2B, 0x60, 0x98"
simulator {
status "button 1 pushed": "command: 9881, payload: 00 5B 03 DE 00 01"
// need to redo simulator commands
tiles {
standardTile("button", "device.button", width: 2, height: 2) {
state "default", label: "", icon: "st.Home.home30", backgroundColor: "#ffffff"
valueTile(“battery”, “device.battery”, inactiveLabel: false, decoration: “flat”) {
tileAttribute (“device.battery”, key: “PRIMARY_CONTROL”){
state “battery”, label:’${currentValue}% battery’, unit:""
standardTile(“configure”, “device.button”, width: 1, height: 1, decoration: “flat”) {
state “default”, label: “configure”, backgroundColor: “#ffffff”, action: “configure”
main "button"
details([“button”, “battery”, “configure”])
def results = []
log.debug(“RAW command: $description”)
if (description.startsWith(“Err”)) {
log.debug(“An error has occurred”)
else {
def cmd = zwave.parse(description.replace("98C1", "9881"), [0x98: 1, 0x20: 1, 0x84: 1, 0x80: 1, 0x60: 3, 0x2B: 1, 0x26: 1])
log.debug "Parsed Command: $cmd"
if (cmd) {
results = zwaveEvent(cmd)
// OLD logic for default configuration:
def BUTTON_IDs = [ 1, 2, 5, 6 ]
// Split string by comma xter, will return an array.
String [] sections = description.split( “,” )
// log.debug(“sections: $sections”)
// Remove all whitespace from beginning and end of each section string.
for (def i = 0; i < sections.length; i++) {
sections[ i ] = sections[ i ].trim()
// log.debug(“Trimmed sections: $sections”)
// Fetch the command and payload strings from the sections array.
String command = sections[ 1 ]
String payload = sections[ 2 ]
// log.debug( “Command: $command” )
// log.debug( “Payload: $payload” )
// Get the command ID and payload ID from these strings.
String commandID = command[-4…-1]
String payloadID = payload[-2…-1]
// log.debug( “CommandID: $commandID” )
// log.debug( “PayloadID: $payloadID” )
// Coerce the payloadID to a Number from a string (using base 10 as radix)
Integer payloadIDint = payloadID.toInteger()
// log.debug(payloadIDint)
// Determine which button was pressed.
if ( commandID == “9881” && payloadIDint == BUTTON_IDs[ 0 ]) {
Integer button = 1
results = createEvent(name: “button”, value: “pushed”, data: [buttonNumber: button], descriptionText: “$device.displayName button $button was pushed”, isStateChange: true)
log.debug( “Button $button was pushed” )
else if ( commandID == “9881” && payloadIDint == BUTTON_IDs[ 1 ]) {
Integer button = 2
else if ( commandID == “9881” && payloadIDint == BUTTON_IDs[ 2 ]) {
Integer button = 3
else if ( commandID == “9881” && payloadIDint == BUTTON_IDs[ 3 ]) {
Integer button = 4
else if ( commandID == “98C1” && payloadIDint == BUTTON_IDs[ 0 ]) {
Integer button = 1
results = createEvent(name: “button”, value: “held”, data: [buttonNumber: button], descriptionText: “$device.displayName button $button was held”, isStateChange: true)
log.debug( “Button $button was held” )
else if ( commandID == “98C1” && payloadIDint == BUTTON_IDs[ 1 ]) {
Integer button = 2
results = createEvent(name: “button”, value: “held”, data: [buttonNumber: button], descriptionText: “$device.displayName button $button was pushed”, isStateChange: true)
else if ( commandID == “98C1” && payloadIDint == BUTTON_IDs[ 2 ]) {
Integer button = 4
else if ( commandID == “98C1” && payloadIDint == BUTTON_IDs[ 3 ]) {
Integer button = 4
else {
log.debug( “Commands and Button ID combinations unaccounted for happened” )
return results
// return commandID
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x98: 1, 0x20: 1])
// can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
log.debug(encapsulatedCommand)
return zwaveEvent(encapsulatedCommand)
def zwaveEvent(physicalgraph.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
log.debug( “keyAttributes: $cmd.keyAttributes”)
log.debug( “sceneNumber: $cmd.sceneNumber”)
log.debug( “sequenceNumber: $cmd.sequenceNumber”)
// log.debug( “payload: $cmd.payload”)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd) {
[ createEvent(descriptionText: “${device.displayName} woke up”),
response(zwave.wakeUpV1.wakeUpNoMoreInformation()) ]
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelGet cmd) {
log.debug “Multilevel get: $cmd”
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
log.debug “Multilevel report: $cmd”
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: “battery”, unit: “%” ]
if (cmd.batteryLevel == 0xFF) { // Special value for low battery alert
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
log.debug (“Battery: $cmd.batteryLevel”)
// Store time of last battery update so we don’t ask every wakeup, see WakeUpNotification handler
state.lastbatt = new Date().time
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd){
log.debug “basic event: $cmd.value”
def zwaveEvent(physicalgraph.zwave.commands.sceneactivationv1.SceneActivationSet cmd) {
log.debug( “Dimming Duration: $cmd.dimmingDuration”)
log.debug( “Button code: $cmd.sceneId”)
if ( cmd.sceneId == 11 ) {
Integer button = 1
sendEvent(name: "button", value: "pushed", data: [buttonNumber: button], descriptionText: "$device.displayName button $button was pushed", isStateChange: true)
log.debug( "Button $button was pushed" )
else if ( cmd.sceneId == 13 ) {
Integer button = 1
sendEvent(name: "button", value: "holdStart", data: [buttonNumber: button], descriptionText: "Button $button is closed")
log.debug( "Button $button Hold start" )
else if ( cmd.sceneId == 15 ) {
Integer button = 1
sendEvent(name: "button", value: "holdRelease", data: [buttonNumber: button], descriptionText: "Button $button is open")
log.debug( "Button $button Hold stop" )
else if ( cmd.sceneId == 21 ) {
Integer button = 2
else if ( cmd.sceneId == 22 ) {
Integer button = 2
sendEvent(name: "button", value: "doubleClick", data: [buttonNumber: button], descriptionText: "$device.displayName button $button was pushed", isStateChange: true)
log.debug( "Button $button was Double Clicked" )
else if ( cmd.sceneId == 23 ) {
Integer button = 2
else if ( cmd.sceneId == 25 ) {
Integer button = 2
else if ( cmd.sceneId == 12 ) {
Integer button = 3
else if ( cmd.sceneId == 14 ) {
Integer button = 3
else if ( cmd.sceneId == 16 ) {
Integer button = 3
else if ( cmd.sceneId == 41 ) {
Integer button = 4
else if ( cmd.sceneId == 42 ) {
Integer button = 4
else if ( cmd.sceneId == 43 ) {
Integer button = 4
else if ( cmd.sceneId == 45 ) {
Integer button = 4
else {
log.debug( "Commands and Button ID combinations unaccounted for happened" )
[ descriptionText: “$device.displayName: $cmd”, linkText:device.displayName, displayed: false ]
log.debug “command event: $cmd”
def configure() {
def commands = [ ]
// Correct configure for dim events:
for (def i = 11; i <= 12; i++) {
commands << zwave.associationV1.associationSet(groupingIdentifier: 4, nodeId: zwaveHubNodeId).format()
// commands << zwave.sceneControllerConfV1.sceneControllerConfSet(groupId:i, sceneId:i).format()
commands << zwave.configurationV1.configurationSet(parameterNumber:i, size:1, scaledConfigurationValue:4).format()
for (def i = 13; i <= 14; i++) {
commands << zwave.associationV1.associationSet(groupingIdentifier: 5, nodeId: zwaveHubNodeId).format()
// Correct configure for default hold trigger:
for (def i = 11; i <= 14; i++) {
// commands << zwave.associationV1.associationSet(groupingIdentifier: 2, nodeId: zwaveHubNodeId).format()
commands << zwave.configurationV1.configurationSet(parameterNumber:i, size:1, scaledConfigurationValue:8).format()
log.debug("Sending configuration: ${commands}")
delayBetween(commands, 1250)
