Help in running custom command after removing rule machine
Hi Everyone,
Is there a way to associate a custom command to a virtual device?
So when I turn the virtual device on it send the command to the actual device…
Recently I deleted rule machine in order to organize everything from scratch.
I didn’t realized that the app is no longer available :frowning:
I used custom command to run my fibaro RGBW deepfade() and police(), but now I don’t know how to do this without rule machine.
I did tried to install the rule machine (Version 1.9.0aX) and rule (Version 1.2.3a) found in Github’s Commit History but the ‘run custom commend’ section seems to be gone. :pensive:
Github - bravenel commits
Any solution / example / advice will be grate!
thanks,
Gil :slight_smile:
Did you delete it from your IDE or just remove the installed instance?
In order to assign custom commands to a virtual switch you need to have a SmartApp which associates the two.
yes I removed all the rules from the app, and removed the app complitly from the IDE…
Usually I used the rule app as a way to associate the two…
any suggestion?
thanks,
Gil. :slight_smile:
Well, you won’t be able to get Rule Machine back so it looks like you’ll have to create a custom SmartApp…
My coding skills are not that good…
:sob:
I’ve written a Smart App to just this. If you (or anyone else) would like a copy of it to test, please let me know.
I plan to publish it on github, but want to get a few miles on it first. I wrote it over the Memorial Day weekend and it’s been working fine since.
I’ve published the first version of this on github:
I’ll get a proper release notice out in the next week.
Thanks for sharing man.
This is exactly what I needed!
So far works grate!
Gil :slight_smile:
Thanks. You’re the first person other than me to use it, so please let me know if you find any bugs or have suggestions.
If I’ll find something… but for now It works perfectly!
Thanks again.
Gil :slight_smile:
The need for this was discussed under Smart Rules, since it doesn’t have a custom command functionality.
Thank you!
George,
I’m a Smart Rules user and did this app specifically to provide a way for Smart Rules to trigger custom commands. I set up a set of virtual momentaries to use as trigger devices in my app and then use Smart Rules to turn on the momentaries as appropriate.
If you want to post a pointer to this thread in the discussions you reference, that would be great.
My next step is to restructure this app as a Parent-Child Smartapp to improve the usability a little, but the core functionality will stay the same.
There’s also CoRE :smiley:
Insanely powerful… still in Alpha, but many RM users have switched everything over, it’s doing amazing things
Custom commands are sorted out very well in the app as of recently
